path: root/testsuites/aclocal/rtems-bsp-includes.m4 (follow)
* */aclocal/*: Remove remnants of autoconf/automae build systemJoel Sherrill2021-11-291-13/+0
| | | | Updates #4081.
* Remove make preinstallChris Johns2018-01-251-0/+13
