Enable an individual testsuite only through the corresponding enable.
Use BUILD_TESTS to change the default value of the individual testsuite
enable options. This allows the user to enable all testsuites with
specific exceptions.
For example, this builds all testsuites except the benchmarks:
[arch/bsp]
BUILD_TESTS = True
BUILD_BENCHMARKS = False
Explicitly test the 64-bit integer division and modulo operations. They
are essential for the timekeeping services. On most 32-bit targets,
they need a software implementation.
Update #3716.
This unit test covers code paths which are only reached if unlimited
objects are used.
Update #3716.
This unit test covers code paths of the Message Handler which are only
reached by through POSIX message queue API.
Update #3716.
brains GmbH.
Propagate the group defined cppflags, cflags, and cxxflags from parent groups
to child items through the build item context.
Update #4670.
