Enable an individual testsuite only through the corresponding enable.
Use BUILD_TESTS to change the default value of the individual testsuite
enable options. This allows the user to enable all testsuites with
specific exceptions.
For example, this builds all testsuites except the benchmarks:
[arch/bsp]
BUILD_TESTS = True
BUILD_BENCHMARKS = False
brains GmbH.
This adds the configure option CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR
which allows the application to choose whether to have the POSIX
timer_create() function follow the behavior defined by POSIX or
the FACE Technical Standard.
Updates #4691.
Propagate the group defined cppflags, cflags, and cxxflags from parent groups
to child items through the build item context.
Update #4670.
Close #4645.
Add a test to verify that mapping of machine exceptions to POSIX signals
operates properly when the application requests it.
The linker flag to wrap putchar was lost in translation from make to waf.
Closes #3373
confstr() style update
Signed-off-by: Eshan Dhawan <eshandhawan51@gmail.com>
Update #3818.
