path: root/spec/build/cpukit/optvermin.yml (follow)
* build: Optionally use a VERSION fileSebastian Huber2023-08-021-13/+0
| | | | | | | | | | Define the RTEMS version in the wscript. Optionally use a VERSION file to change the default values of the wscript. Allow the command line option --rtems-version to override __RTEMS_MAJOR__. Remove support for command line configurable options (--rtems-option). Rename internal define RTEMS_VERSION_VC_KEY to RTEMS_VERSION_CONTROL_KEY.
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* build: Use enabled by for defaultsSebastian Huber2023-01-171-2/+1
| | | | | | | | | | | | | | Merge the "default" and "default-by-variant" attributes. Use an "enabled-by" expression to select the default value based on the enabled set. This makes it possible to select default values depending on other options. For example you could choose memory settings based on whether RTEMS_SMP is enabled or disabled. The change was tested by comparing the output of ./waf bspdefaults before and after the change.
* build: Merge default-by-family into by-variantSebastian Huber2021-08-181-1/+0
| | | | | | | Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468.
* build: Use BSP family for optionsChris Johns2021-07-151-0/+1
| | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468
* build: Alternative build system based on wafSebastian Huber2020-09-141-0/+14
Update #3818.
