Define the RTEMS version in the wscript. Optionally use a VERSION file
to change the default values of the wscript. Allow the command line
option --rtems-version to override __RTEMS_MAJOR__. Remove support for
command line configurable options (--rtems-option).
Rename internal define RTEMS_VERSION_VC_KEY to
RTEMS_VERSION_CONTROL_KEY.
brains GmbH.
Merge the "default" and "default-by-variant" attributes. Use an
"enabled-by" expression to select the default value based on the enabled
set. This makes it possible to select default values depending on other
options. For example you could choose memory settings based on whether
RTEMS_SMP is enabled or disabled.
The change was tested by comparing the output of
./waf bspdefaults
before and after the change.
Update #4548.
tools can be tested"
This reverts commit d1bbfbea5f60f552b2b3138bb1df35c3372f2461.
be tested
Prefix the BSP family name with "bsps/" to make it distinct to the BSP
variant names.
Update #4468.
- Optionally add support for 'default-by-family' to allow
option to be set by a family and so all related BSPs
Close #4468
Update #3818.
