* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | libmisc/shell: Add flashdev command | Aaron Nyholm | 2023-05-16 | 1 | -0/+1 |
* | libmisc/shell: Add an 'rtems' command to report a running build | Chris Johns | 2022-08-03 | 1 | -0/+1 |
| | | | | - Report version, cpu, bsp, tools and options. | ||||
* | build: Sort source lists | Sebastian Huber | 2021-02-24 | 1 | -3/+3 |
| | | | | Use the Python sorted() function to sort the "source" lists. | ||||
* | shell: Add i2c and spi commands | Christian Mauderer | 2020-12-14 | 1 | -0/+4 |
| | | | | | | | | This adds some commands that are usefull for debugging simple serial interfaces. Even if they are a complete re-implementation, the i2c* commands use a simmilar call like the Linux i2c tools. | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 1 | -0/+115 |
Update #3818. |
