* | build: Do not use coverage for librtemstest | Sebastian Huber | 2023-11-03 | 1 | -2/+4 |
| | | | | | The goal is to get code and branch coverage from actual tests and not the test support itself. | ||||
* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | TFTPFS: Implement block and window size options | Frank Kühndel | 2022-06-21 | 1 | -1/+2 |
| | | | | | | | | | | | | | | | | | | | | | The original file cpukit/libfs/src/ftpfs/tftpDriver.c is split into two: tftpfs.c - This file contains the code from tftpDriver.c related to file system operations such as mount(), open(), read(), and so on. tftpDriver.c - In the original file remains only the code related to networking. This code implements the Trivial File Transfer Protocol (TFTP). Moreover, the code is extended to support * RFC 2347 TFTP Option Extension * RFC 2348 TFTP Blocksize Option * RFC 7440 TFTP Windowsize Option Update #4666. | ||||
* | cpukit: Move ftpfs from libnetworking to libfs | Vijay Kumar Banerjee | 2021-04-07 | 1 | -1/+1 |
| | | | | Update #3850 | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 1 | -0/+20 |
Update #3818. |
