The <rtems/test-info.h> header file is required for every RTEMS test
program. Move the RTEMS test printer support to a dedicated header file
<rtems/test-printer.h>. This removes an unnecessary dependency to the
RTEMS printer support in <rtems/test-info.h>.
Tests using the RTEMS Testing Framework no longer depend on the
<rtems/printer.h>.
Move <rtems/score/gcov.h> to <rtems/test-gcov.h>. These functions do
not belong to an super core service.
brains GmbH.
Update #4670.
Update #4670.
Add support to record scheduler operations. This support is especially
important for tests in SMP configurations since the thread switch extension is
quite difficult to use due to the asynchronous nature of thread dispatching.
In contrast, the scheduler operations occur normally in a deterministic order.
Update #3716.
Use the Python sorted() function to sort the "source" lists.
This primitive test case memory allocator uses memory from the low-level
memory information provided by the BSP. At the beginning of each test
case, the memory available to the test case is reinitialized. This
allows the use of a simple allocate only allocator.
Update #3818.
