* | build: Do not install removed files | Sebastian Huber | 2023-06-12 | 1 | -1/+0 |
* | spec/bsps/aarch64: Install ELF machine types for libdl | Chris Johns | 2022-08-22 | 1 | -0/+3 |
| | | | | Updates #4705 | ||||
* | aarch64: Break out MMU definitions | Kinsey Moore | 2021-11-01 | 1 | -0/+1 |
| | | | | | | This moves the AArch64 MMU memory type definitions into cpukit for use by libdebugger since remapping of memory is required to insert software breakpoints. | ||||
* | bsps/aarch64: Break out system registers | Kinsey Moore | 2021-05-27 | 1 | -0/+1 |
| | | | | | Break out system register definitions and accessors so that they're usable by other parts of RTEMS. | ||||
* | build: Sort source lists | Sebastian Huber | 2021-02-24 | 1 | -5/+5 |
| | | | | Use the Python sorted() function to sort the "source" lists. | ||||
* | score: Add AArch64 port | Kinsey Moore | 2020-10-05 | 1 | -0/+36 |
This adds a CPU port for AArch64(ARMv8) with support for exceptions and interrupts. |
