path: root/spec/build/bsps/riscv (follow)
* build: Use common objects item for get memorySebastian Huber2021-11-304-2/+4
* build: Merge default-by-family into by-variantSebastian Huber2021-08-189-9/+0
| | | | | | | Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468.
* bsps: Move optfdt* files to shared parent directorypranav2021-08-095-69/+4
* build: Use BSP family for optionsChris Johns2021-07-1513-0/+13
| | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468
* bsps/riscv: Support RTEMS_NOINIT in linkcmdsSebastian Huber2021-05-031-0/+7
| | | | Update #3866.
* spec: Remove residue bsps spec filesVijay Kumar Banerjee2021-04-071-18/+0
| | | | Update #3850
* spec: Remove RTEMS_NETWORKING optionsVijay Kumar Banerjee2021-04-071-2/+0
| | | | Update #3850
* bsps: Add default rtems_get_target_hash()Sebastian Huber2021-02-262-0/+2
| | | | Update #4267.
* bsps: Add missing DWARF 5 sectionsSebastian Huber2021-01-261-3/+5
| | | | Sort alphabetically.
* bsps: Support DWARF 5 sectionsSebastian Huber2021-01-251-8/+12
| | | | GCC 11 uses DWARF 5 by default.
* Add correct link address for griscv waf buildJiri Gaisler2020-11-092-0/+6
* Add networking support for griscv bspJiri Gaisler2020-11-092-0/+20
| | | | | | | * Only GRETH device supported for now * Fix endian problem in GRETH driver * Remove SPARC assembly from greth.c * Builds with both autoconf and waf
* build: Alternative build system based on wafSebastian Huber2020-09-1442-0/+1338
Update #3818.
