path: root/spec/build/bsps/riscv (follow)
* bsps: Add default rtems_get_target_hash()Sebastian Huber2021-02-262-0/+2
| | | | Update #4267.
* bsps: Add missing DWARF 5 sectionsSebastian Huber2021-01-261-3/+5
| | | | Sort alphabetically.
* bsps: Support DWARF 5 sectionsSebastian Huber2021-01-251-8/+12
| | | | GCC 11 uses DWARF 5 by default.
* Add correct link address for griscv waf buildJiri Gaisler2020-11-092-0/+6
* Add networking support for griscv bspJiri Gaisler2020-11-092-0/+20
| | | | | | | * Only GRETH device supported for now * Fix endian problem in GRETH driver * Remove SPARC assembly from greth.c * Builds with both autoconf and waf
* build: Alternative build system based on wafSebastian Huber2020-09-1442-0/+1338
Update #3818.
