* | 2001-09-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-09-13 | 1 | -1/+6 |
| | | | | | | | | | | | * configure.in: Add RTEMS specific version of EXEEXT test. * mkgdbspec.in, mkgnatnewlibspec.in, gdb/gdb.spec.in, gnatnewlib/gnatnewlib.spec.in: Change to Target_alias to avoid conflicts with new autoconf/automake. * setup, setup.def, mkgnatnewlibspec.in: Add gnat_newlib_patch_version variable. * gnatnewlib/Makefile.am: Add i386-rtemscoff target in attempt to build it. | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -12/+9 |
* | Successfully built some RPMs. There is still a lot of work to do. | Joel Sherrill | 2000-01-31 | 1 | -0/+4 |
* | First attempt at debugging. | Joel Sherrill | 2000-01-26 | 1 | -36/+0 |
* | First cut at adding RPM scripts for building GNAT/RTEMS RPMs. | Joel Sherrill | 2000-01-26 | 1 | -0/+61 |
