path: root/scripts-ada/gdb/gdb.spec.in (follow)
* 2002-08-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-201-152/+0
| | | | | | | | | | | | * .cvsignore, ChangeLog, Makefile.am, README, TODO, buildall.in, configure.ac, install-sh, missing, mkbinutilspec.in, mkbspspec.in, mkgdbspec.in, mkgnatnewlibspec.in, mkinstalldirs, mkrpms, mkspec, setup, setup.def, binutils/.cvsignore, binutils/Makefile.am, binutils/binutils.spec.in, gdb/.cvsignore, gdb/Makefile.am, gdb/gdb.spec.in, gnatnewlib/.cvsignore, gnatnewlib/Makefile.am, gnatnewlib/gnatnewlib.spec.in: Per PR238 GNAT support is now included in the main RPM specs which support gcc 3.1 and newer since GNAT is in that source base now.
* 2001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-131-14/+14
| | | | | | | | | | | * configure.in: Add RTEMS specific version of EXEEXT test. * mkgdbspec.in, mkgnatnewlibspec.in, gdb/gdb.spec.in, gnatnewlib/gnatnewlib.spec.in: Change to Target_alias to avoid conflicts with new autoconf/automake. * setup, setup.def, mkgnatnewlibspec.in: Add gnat_newlib_patch_version variable. * gnatnewlib/Makefile.am: Add i386-rtemscoff target in attempt to build it.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-181-1/+2
| | | | | * setup.def, gdb/gdb.spec.in,gnatnewlib/gnatnewlib.spec.in: Updated to reflect gnat 3.13p successfully building.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-3/+3
* Put Ada scripts in group gnatrtems.Joel Sherrill2000-01-281-1/+1
* GNAT/RTEMS RPMs have built for the binutils/gnat/gcc combinationJoel Sherrill2000-01-271-8/+15
| | | | and appear to be close for gdb.
* First attempt at debugging.Joel Sherrill2000-01-261-32/+32
* First cut at adding RPM scripts for building GNAT/RTEMS RPMs.Joel Sherrill2000-01-261-0/+144
