* | 2002-08-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-20 | 1 | -62/+0 |
| | | | | | | | | | | | | * .cvsignore, ChangeLog, Makefile.am, README, TODO, buildall.in, configure.ac, install-sh, missing, mkbinutilspec.in, mkbspspec.in, mkgdbspec.in, mkgnatnewlibspec.in, mkinstalldirs, mkrpms, mkspec, setup, setup.def, binutils/.cvsignore, binutils/Makefile.am, binutils/binutils.spec.in, gdb/.cvsignore, gdb/Makefile.am, gdb/gdb.spec.in, gnatnewlib/.cvsignore, gnatnewlib/Makefile.am, gnatnewlib/gnatnewlib.spec.in: Per PR238 GNAT support is now included in the main RPM specs which support gcc 3.1 and newer since GNAT is in that source base now. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -2/+2 |
| | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * binutils/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * gdb/Makefile.am: Remove AUTOMAKE_OPTIONS. * gnatnewlib/Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 1 | -0/+62 |
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. |
