path: root/scripts-ada/binutils/.cvsignore (follow)
* 2002-08-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-201-4/+0
| | | | | | | | | | | | * .cvsignore, ChangeLog, Makefile.am, README, TODO, buildall.in, configure.ac, install-sh, missing, mkbinutilspec.in, mkbspspec.in, mkgdbspec.in, mkgnatnewlibspec.in, mkinstalldirs, mkrpms, mkspec, setup, setup.def, binutils/.cvsignore, binutils/Makefile.am, binutils/binutils.spec.in, gdb/.cvsignore, gdb/Makefile.am, gdb/gdb.spec.in, gnatnewlib/.cvsignore, gnatnewlib/Makefile.am, gnatnewlib/gnatnewlib.spec.in: Per PR238 GNAT support is now included in the main RPM specs which support gcc 3.1 and newer since GNAT is in that source base now.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-0/+1
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+3
