* | Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>). | Ralf Corsepius | 2009-10-15 | 1 | -28/+0 |
* | 2009-09-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-14 | 1 | -1/+1 |
| | | | | * custom/gen83xx.cfg: Remove -funit-at-a-time. | ||||
* | Remove RTEMS_BOARD_MODEL, RTEMS_83XX_DERIVATE. | Ralf Corsepius | 2008-10-02 | 1 | -2/+1 |
* | Back out parts of yesterdays changes. | Ralf Corsepius | 2008-10-01 | 1 | -2/+2 |
* | 2008-10-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-10-01 | 1 | -1/+1 |
| | | | | * custom/gen83xx.cfg, custom/lpc2478.cfg: Remove warning flags. | ||||
* | Remove RTEMS_BOARD_MODEL. | Ralf Corsepius | 2008-09-30 | 1 | -1/+1 |
* | 2008-09-09 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-09 | 1 | -1/+1 |
| | | | | | | | | | * leaf.cfg, compilers/gcc-target-default.cfg, custom/bf537Stamp.cfg, custom/gen5200.cfg, custom/gen83xx.cfg, custom/genmcf548x.cfg, custom/mbx8xx.cfg, custom/mpc55xx.cfg, custom/nds.cfg, custom/pc386.cfg, custom/tqm8xx.cfg: Remove use of AM_LDFLAGS. Ensure LDFLAGS works all the time. Clean up BSPs which defined their own make-exe rules inappropriately. | ||||
* | updated gen83xx BSP | Thomas Doerfler | 2008-07-14 | 1 | -2/+3 |
| | | | | | updated haleakala BSP added MPC55xx BSP | ||||
* | Make all BSPs use the same rules for invoking gcc and g++ to link an ↵ | Joel Sherrill | 2008-03-06 | 1 | -20/+1 |
| | | | | application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file. | ||||
* | 2007-08-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-08-05 | 1 | -1/+1 |
| | | | | * custom/gen83xx.cfg: Use -O2. | ||||
* | 2007-07-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-07-11 | 1 | -0/+8 |
| | | | | * custom/gen83xx.cfg: Add make-cxx-exe rule. | ||||
* | compilable release of virtex/gen83xx/gen5200 powerpc adaptations. Merged ↵ | Thomas Doerfler | 2007-07-10 | 1 | -0/+39 |
many different versions of new exception handling code to shared sources. |
