* | Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>). | Ralf Corsepius | 2009-10-15 | 1 | -21/+0 |
* | Make all BSPs use the same rules for invoking gcc and g++ to link an ↵ | Joel Sherrill | 2008-03-06 | 1 | -9/+0 |
| | | | | application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file. | ||||
* | Add -g to CFLAGS_OPTIMIZE_V. | Ralf Corsepius | 2007-01-18 | 1 | -1/+1 |
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 1 | -1/+1 |
* | CFLAGS_OPTIMIZE_V = -O2. | Ralf Corsepius | 2007-01-18 | 1 | -3/+1 |
* | Cleanup. | Ralf Corsepius | 2006-11-30 | 1 | -10/+1 |
* | 2005-01-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-20 | 1 | -1/+2 |
| | | | | | | | | * custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/csb336.cfg, custom/csb337.cfg, custom/edb7312.cfg, custom/jmr3904.cfg, custom/pc486.cfg, custom/pc586.cfg, custom/pc686.cfg, custom/pck6.cfg, custom/vegaplus.cfg: Correct use of arguments for gcc 4.x. Hopefully they are still OK for gcc 3.3.5. | ||||
* | Merger from rtems-4-6-branch | Ralf Corsepius | 2003-03-10 | 1 | -1/+1 |
* | 2002-11-13 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 2002-11-13 | 1 | -0/+40 |
* custom/edb7312.cfg: New file. |
