* shell/rtems.t: Add halt command.
* porting/idlethread.t: Change prototype of IDLE thread to consistently
return void * and take a uintptr_t argument.
* bsp_howto/console.t: Clarify interrupt transmit process.
* user/concepts.t: Typo.
* index.html.in: Remove manuals that are dead.
* user/cpuuse.t: Reflect change in CPU Usage report format.
* user/init.t: Eliminate pointers to API configuration tables in the
main configuration table. Reference the main configuration table and
the API configuration tables directly using the confdefs.h version
rather than obtaining a pointer to it. This eliminated some
variables, a potential fatal error, some unnecessary default
configuration structures. Overall, about a 4.5% reduction in the code
size for minimum and hello on the SPARC.
* user/conf.t, user/region.t: Change sizes of heap/region and allocated
objects in heap to intptr_t so they can be larger than a single
allocatable object (e.g. size_t).
* user/region.t: Malloc Family is not implemented in termios of Region
Manager after 4.7. Correct documentation.
* bsp_howto/console.t: Remove size constraints on image. Fix a
sentence.
Joel Sherrrill <joel.sherrill@oarcorp.com>
* bsp_howto/Makefile.am, bsp_howto/console.t: Sebastian improved
documentation for termios device drivers.
* bsp_howto/TERMIOSFlow.eps, bsp_howto/TERMIOSFlow.png: New files.
Joel added Termios Flow figure from RTEMS Open Class material.
* cpu_supplement/.cvsignore, cpu_supplement/Makefile.am,
cpu_supplement/cpu_supplement.texi: Add Lattice Mico32 support.
* cpu_supplement/lm32.t: New file.
* ada_user/Makefile.am: Fix typo.
* ada_user/Makefile.am, user/Makefile.am, user/concepts.t: Add 16 bit
object Id format information.
* user/ObjectId-16Bits.eps, user/ObjectId-16Bits.png: New files.
* user/datatypes.t: Add C99 uint types.
PR 1340/cpukit
* user/chains.t: Add rtems_chain_initialize to public chain API.
PR 1339/Ada
* user/io.t: Re-add IO Manager to Ada binding.
PR 1336/cpukit
* user/chains.t, user/dirstat.texi: Add rtems_chain_prepend_unprotected
and rtems_chain_append_unprotected.
* user/concepts.t: Use 32 bit version centered.
* ada_user/Makefile.am: Make Ada manual build again after adding
figure.
PR 1334/doc
* user/Makefile.am, user/concepts.t, user/init.t, user/overview.t,
user/part.t, user/task.t: Correct typos and correctly document 4
parts of 32-bit object id.
* user/ObjectId-32Bits.eps, user/ObjectId-32Bits.png: New files.
* user/conf.t: Fix typo.
* user/region.t: Change size_t to ssize_t.
* shell/preface.texi: Bump version to 4.9.99.0
* bsp_howto/timer.t: Eliminate uses of old benchmark timer names.
* setup.def, started/buildc.t: Update.
* bsp_howto/BSPInitFlowchart-49.png: Update figure.
* user/conf.t: Add CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM and
CONFIGURE_APPLICATION_DISABLE_FILESYSTEM.
* shell/rtems.t, user/conf.t, user/stackchk.t: Rename STACK_CHECKER_ON
to more appropriate CONFIGURE_STACK_CHECKER_ENABLED.
* user/conf.t: Add support for optionally having a unified work area.
In other words, the RTEMS Workspace and C Program Heap are the same
pool of memory.
* bsp_howto/Developer-User-Timeline.png: Correct figure.
* user/chains.t, user/conf.t, user/object.t, user/userext.t:
More "bool" cleanup.
* bsp_howto/ata.t, bsp_howto/rtc.t, networking/networkapp.t,
user/chains.t, user/stackchk.t: Convert to "bool".
* user/datatypes.t: Add deprecation notices to
"rtems_boolean", "rtems_single", "rtems_double".
* user/intr.t, user/userext.t: Convert to "bool".
* bsp_howto/timer.t: Update documentation to reflect Timer Driver
renaming.
* bsp_howto/clock.t: The Shared Memory Driver no longer requires the
special IOCTL in Clock_control. This was a hack which has existed
since before the Classic API Timer Manager was implemented. All
implementations of and references to Clock_control were removed.
* user/conf.t: Add CONFIGURE_BSP_PREREQUISITE_DRIVERS and
CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS.
* user/object.t: Correct order of arguments.
* user/clock.t: Correct discussion of timeval.
* bsp_howto/init.t: Eliminate empty section.
* bsp_howto/init.t: Complete update.
* bsp_howto/Makefile.am, bsp_howto/init.t, bsp_howto/intro.t,
bsp_howto/makefiles.t, bsp_howto/support.t: Update initialization
sequence. Add another figure.
* bsp_howto/BSPInitFlowchart-49.eps, bsp_howto/BSPInitFlowchart-49.png: New files.
* index.html.in: Reorder manuals.
* bsp_howto/Makefile.am, bsp_howto/linkcmds.t, bsp_howto/makefiles.t,
bsp_howto/target.t: Update some of this manual.
* bsp_howto/Developer-User-Timeline.eps,
bsp_howto/Developer-User-Timeline.png: New files.
* bsp_howto/ata.t, bsp_howto/clock.t, bsp_howto/ide-ctrl.t,
bsp_howto/nvmem.t, bsp_howto/shmsupp.t, user/datatypes.t, user/mp.t,
user/userext.t: Eliminate all references to rtems_signedXX and
rtems_unsignedXX.
* user/msg.t, user/sem.t, user/task.t: Update to new parameter types.
Emphasize that you can use a pointer for task arguments.
