pointers to emacs and vim.
tries to give a pointer about how to approach writing an application.
fixes handling of word-replace and removes tool/update.
structure.
C version of Getting Started.
to work with pdf generation.
how to get it from a file other thatn the executable.
including a new section in the Getting Started called "Where to
Go From Here", lots of index entries added, and more configuration
table information.
<corsepiu@faw.uni-ulm.de> to correct some typos and improve the
information for DDD and the Hitachi SH.
<Stephan.Wilms@CWA.de>.
This directory was removed post-4.0 to be more in compliance with
GNU standards. Reported by Stephan Wilms <Stephan.Wilms@CWA.de>.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
that addresses the following:
The patch below should
* fix the *pdf cleanup handling
* fix dependencies between pdf-documents and texi-files
It also contains an attempt to let networking/schedule.t use states.pdf
instead of ascii graphics, but though each pdf image looks nice, it
comes out weirdly distorted in the main pdf document.
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
