* | Bug fix from Trevin Beattie <trevin@eyring.com> picked up from | Joel Sherrill | 2000-05-28 | 1 | -0/+1 | |
| | | | | | | | | | the bug-texinfo mailing list: There is also a bug in the PDF outline: Any outline item containing an underscore shows up as a bunch of texinfo codes ("@unhbox @kern.06em @vbox{..."). This bug was remedied by the following addition to \pdfmakeoutlines. | |||||
* | Updated to reflect lower confdefs.h values and new control | Joel Sherrill | 2000-05-28 | 2 | -11/+73 | |
| | | | | over number of termios ports. | |||||
* | Minor corrections from Nick Simon <Nick.SIMON@syntegra.bt.co.uk>. | Joel Sherrill | 2000-05-25 | 1 | -2/+2 | |
| | | | | | | - char * nameserver[3] appears twice, second occurrence should be ntpserver - in sect 3.3.3 ...ifcontig should be ifconfig | |||||
* | Corrected paths. | Joel Sherrill | 2000-05-17 | 3 | -7/+7 | |
* | Added information on the location where the tools are installed. | Joel Sherrill | 2000-05-11 | 1 | -0/+10 | |
* | Added "@" in front of "{" and "}" to make texinfo happy. | Joel Sherrill | 2000-05-10 | 2 | -8/+8 | |
* | Made examples include checking of return status. | Joel Sherrill | 2000-05-10 | 2 | -12/+40 | |
* | Removed duplicate NEEDS_CONSOLE_DRIVER. | Joel Sherrill | 2000-05-10 | 1 | -1/+0 | |
* | Typo resulting in bad link fixed. | Joel Sherrill | 2000-05-09 | 1 | -1/+1 | |
* | Added comment on RTEMS_DEFAULT_MODE. | Joel Sherrill | 2000-05-09 | 1 | -0/+3 | |
* | Updated NT editor information to update status on PFE and add | Joel Sherrill | 2000-05-09 | 1 | -6/+24 | |
| | | | | pointers to emacs and vim. | |||||
* | Updated in order to generate a current tool chain documentation set. | Joel Sherrill | 2000-05-09 | 5 | -97/+144 | |
* | Updated. | Joel Sherrill | 2000-05-08 | 2 | -6/+8 | |
* | Updated versions. | Joel Sherrill | 2000-05-08 | 2 | -8/+8 | |
* | Added some more. | Joel Sherrill | 2000-05-08 | 1 | -0/+8 | |
* | Added more information to the "next step" chapter. The new information | Joel Sherrill | 2000-05-08 | 2 | -1/+58 | |
| | | | | tries to give a pointer about how to approach writing an application. | |||||
* | Patch from Ralf Corsepies <corsepiu@faw.uni-ulm.de> that | Joel Sherrill | 2000-05-08 | 3 | -223/+2 | |
| | | | | fixes handling of word-replace and removes tool/update. | |||||
* | Made comment a little more detailed. | Joel Sherrill | 2000-05-08 | 1 | -1/+2 | |
* | Updated. | Joel Sherrill | 2000-05-08 | 1 | -17/+4 | |
* | Added Data Types chapter. | Joel Sherrill | 2000-05-08 | 2 | -2/+4 | |
* | New file datatypes.texi added. | Joel Sherrill | 2000-05-08 | 1 | -0/+1 | |
* | Added Data Types Chapter. | Joel Sherrill | 2000-05-08 | 2 | -3/+10 | |
* | Fixed typo so constand would have "RTEMS_". | Joel Sherrill | 2000-05-08 | 1 | -1/+1 | |
* | Added function index entries for all data types and enhanced introductory | Joel Sherrill | 2000-05-08 | 1 | -3/+85 | |
| | | | | structure. | |||||
* | Fixed type so constant would have "RTEMS_" in front of it. | Joel Sherrill | 2000-05-08 | 1 | -1/+1 | |
* | Now sharing the "buildrt.t" or Building RTEMS chapter with the | Joel Sherrill | 2000-05-08 | 2 | -142/+4 | |
| | | | | C version of Getting Started. | |||||
* | New file. | Joel Sherrill | 2000-05-05 | 1 | -0/+229 | |
* | Updated example. | Joel Sherrill | 2000-05-05 | 1 | -56/+18 | |
* | Added function indexes for CONFIGURE_ constants. | Joel Sherrill | 2000-05-05 | 1 | -1/+85 | |
* | More updates. | Joel Sherrill | 2000-05-05 | 2 | -4/+4 | |
* | Added much information on confdefs.h parameters. | Joel Sherrill | 2000-05-05 | 1 | -78/+437 | |
* | Modifed to avoid using @uref directive since that does not seem | Joel Sherrill | 2000-05-04 | 3 | -19/+34 | |
| | | | | to work with pdf generation. | |||||
* | More information on what symbolic information is for and | Joel Sherrill | 2000-05-04 | 1 | -0/+13 | |
| | | | | how to get it from a file other thatn the executable. | |||||
* | Added nextstep.texi | Joel Sherrill | 2000-05-04 | 1 | -0/+1 | |
* | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 2000-05-04 | 31 | -140/+508 | |
| | | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | |||||
* | New file. | Joel Sherrill | 2000-05-04 | 1 | -0/+72 | |
* | Patch rtemsdoc-4.5.0-rc-4-cvs.diff from Ralf Corsepius | Joel Sherrill | 2000-05-02 | 2 | -8/+31 | |
| | | | | | <corsepiu@faw.uni-ulm.de> to correct some typos and improve the information for DDD and the Hitachi SH. | |||||
* | Modified to correct references to gmake per comment from Stephan Wilms | Joel Sherrill | 2000-05-02 | 5 | -10/+17 | |
| | | | | <Stephan.Wilms@CWA.de>. | |||||
* | RTEMS_MAKEFILE_PATH instructions incorrectly included rtems subdirectory. | Joel Sherrill | 2000-05-02 | 1 | -2/+5 | |
| | | | | | This directory was removed post-4.0 to be more in compliance with GNU standards. Reported by Stephan Wilms <Stephan.Wilms@CWA.de>. | |||||
* | A bit more explanation for task variables per Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 2000-05-01 | 1 | -0/+7 | |
* | File rendered obsolete by rtemsdoc-4.5.0-rc-3.diff from | Joel Sherrill | 2000-05-01 | 1 | -342/+0 | |
| | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | |||||
* | Removed file rendered obsolete by rtemsdoc-4.5.0-rc-3.diff from | Joel Sherrill | 2000-05-01 | 2 | -90/+1 | |
* | New file added by rtemsdoc-4.5.0-rc-3.diff from | Joel Sherrill | 2000-05-01 | 1 | -0/+1045 | |
* | Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 2000-05-01 | 56 | -644/+595 | |
| | | | | | | | | | | | | | | | | | | | | | | | | | It addresses: * .cvsignore (only minor changes to yours, as they were pretty clean, most changes result from my mkcvsignore script being overly pedantic sorting entries alphabetically.) * timing.t handling and time<BSP>_.texi handling in supplements * network.t handling in bsp_howto * RTEMS_DATE and RTEMS_UPDATE handling in configure.in. [It actually is a hack, as we could apply automake's version.texi handling instead - I know think to understand what automake does with it.] * avoid using temporary files; Therefore a new tool called bmenu2, derived from bemenu, is introduced, which reads a single file from stdin and writes to stdio. To apply: cd rtemsdoc patch -p1 < rtemsdoc-4.5.0-rc-3.diff cvs rm -f bsp_howto/network.t cvs add tools/bmenu/bmenu2.c ./bootstrap BTW: word-replace now is unused. It could be removed if you like to. | |||||
* | Updated. | Joel Sherrill | 2000-04-27 | 1 | -0/+13 | |
* | New files. First attempt. | Joel Sherrill | 2000-04-27 | 41 | -0/+861 | |
* | Updated. | Joel Sherrill | 2000-04-27 | 1 | -13/+24 | |
* | Removed -- temporary files. | Joel Sherrill | 2000-04-27 | 8 | -11515/+0 | |
* | Files moved around and missed in the previous commit. | Joel Sherrill | 2000-04-27 | 11 | -0/+14 | |
* | Modified to give rpm removal command instead of install command again. | Joel Sherrill | 2000-04-27 | 1 | -6/+6 | |
