* | Removed old bmenu version. | Joel Sherrill | 2000-06-01 | 2 | -1067/+1 |
* | Removed since unused. | Joel Sherrill | 2000-06-01 | 1 | -22/+0 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to: | Joel Sherrill | 2000-06-01 | 2 | -8/+16 |
| | | | | | | | | | | This patch changes the installation directory of the supplements to supplements/<cpu>. This allows browsing the html files inside of the source tree, because after having applied this patch, the structure of the html installation directory hierarchy is the same as the directory structure of the source tree. | ||||
* | Readding. | Joel Sherrill | 2000-06-01 | 1 | -0/+65 |
* | Patch rtemsdoc-4.5.0-rc-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-06-01 | 140 | -1579/+1473 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Ralf's comments follow: Changes: * Enhanced versioning: - Addition of automake's version.texi support - Replacement of rtemsdoc's former versioning support by automake's versioning support (Abandoning RTEMS-UPDATE-* etc.) - Abandoning setup.texi.in - Add EDITION to each documents Makefile.am - version.texi support in project.am - Addition of maintainer mode (currently only used to prevent incorrectly updating timestamps when users touch automake's version.texi timestamp files (stamp-vti)). * Fixing info dir support - Use texinfo's @dircategory and @direntry instead of infos *-DIR-ENTRY - $(infodir)/dir is now correctly set up * Avoid using temporary files - Pipe texts through REPLACE2 into BMENU2 instead of using temporary files. - Abandon using bmenu in favor of bmenu2 (bmenu could be removed now) * Prepare Makefile.ams for building in a separate buildtree - prefix files with $(srcdir) in Makefile.am for files which must be generated inside of the source tree Notes: * rtemsdoc can not yet be build in a separate source-tree, but we are very close to it. * You as the maintainer of this package now should always use --enable-maintainer-mode to configure rtemsdoc. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 2000-05-31 | 1 | -3/+17 |
| | | | | | | Adds a -I <path> option to texi2www. This option is supposed to compatible to the option of the same name in makeinfo, texi2dvi etc. [This patch actually is kind of a hack, but it works :] | ||||
* | Typo caught by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-05-31 | 1 | -1/+1 |
* | Corrected instructions. | Joel Sherrill | 2000-05-28 | 1 | -0/+2 |
* | Corrected typo. | Joel Sherrill | 2000-05-28 | 1 | -1/+1 |
* | Added information on Application Makefiles. | Joel Sherrill | 2000-05-28 | 1 | -0/+13 |
* | Added information on how to do this step if you installed tool | Joel Sherrill | 2000-05-28 | 1 | -1/+21 |
| | | | | binaries rather than unpacking everything. | ||||
* | Added start-? | Joel Sherrill | 2000-05-28 | 2 | -1/+2 |
* | Added build45.texi. | Joel Sherrill | 2000-05-28 | 1 | -0/+1 |
* | Reformatted ASCII slightly to avoid line wrap. | Joel Sherrill | 2000-05-28 | 1 | -3/+4 |
* | Merged Ralf Corsepius' 4.5 Build Issues FAQ into this. | Joel Sherrill | 2000-05-28 | 4 | -2/+369 |
* | Patch obtain from bug-texinfo mailing list from Trevin Beattie | Joel Sherrill | 2000-05-28 | 1 | -2/+5 |
| | | | | | <trevin@eyring.com> to make hyperlinks take you to the top of a page rather than the bottom. | ||||
* | Change linkcolor to Blue from Cyan per patch from Trevin Beattie | Joel Sherrill | 2000-05-28 | 1 | -1/+1 |
| | | | | <trevin@eyring.com> obtained from bug-texinfo mailing list. | ||||
* | Bug fix from Trevin Beattie <trevin@eyring.com> picked up from | Joel Sherrill | 2000-05-28 | 1 | -0/+1 |
| | | | | | | | | | the bug-texinfo mailing list: There is also a bug in the PDF outline: Any outline item containing an underscore shows up as a bunch of texinfo codes ("@unhbox @kern.06em @vbox{..."). This bug was remedied by the following addition to \pdfmakeoutlines. | ||||
* | Updated to reflect lower confdefs.h values and new control | Joel Sherrill | 2000-05-28 | 2 | -11/+73 |
| | | | | over number of termios ports. | ||||
* | Minor corrections from Nick Simon <Nick.SIMON@syntegra.bt.co.uk>. | Joel Sherrill | 2000-05-25 | 1 | -2/+2 |
| | | | | | | - char * nameserver[3] appears twice, second occurrence should be ntpserver - in sect 3.3.3 ...ifcontig should be ifconfig | ||||
* | Corrected paths. | Joel Sherrill | 2000-05-17 | 3 | -7/+7 |
* | Added information on the location where the tools are installed. | Joel Sherrill | 2000-05-11 | 1 | -0/+10 |
* | Added "@" in front of "{" and "}" to make texinfo happy. | Joel Sherrill | 2000-05-10 | 2 | -8/+8 |
* | Made examples include checking of return status. | Joel Sherrill | 2000-05-10 | 2 | -12/+40 |
* | Removed duplicate NEEDS_CONSOLE_DRIVER. | Joel Sherrill | 2000-05-10 | 1 | -1/+0 |
* | Typo resulting in bad link fixed. | Joel Sherrill | 2000-05-09 | 1 | -1/+1 |
* | Added comment on RTEMS_DEFAULT_MODE. | Joel Sherrill | 2000-05-09 | 1 | -0/+3 |
* | Updated NT editor information to update status on PFE and add | Joel Sherrill | 2000-05-09 | 1 | -6/+24 |
| | | | | pointers to emacs and vim. | ||||
* | Updated in order to generate a current tool chain documentation set. | Joel Sherrill | 2000-05-09 | 5 | -97/+144 |
* | Updated. | Joel Sherrill | 2000-05-08 | 2 | -6/+8 |
* | Updated versions. | Joel Sherrill | 2000-05-08 | 2 | -8/+8 |
* | Added some more. | Joel Sherrill | 2000-05-08 | 1 | -0/+8 |
* | Added more information to the "next step" chapter. The new information | Joel Sherrill | 2000-05-08 | 2 | -1/+58 |
| | | | | tries to give a pointer about how to approach writing an application. | ||||
* | Patch from Ralf Corsepies <corsepiu@faw.uni-ulm.de> that | Joel Sherrill | 2000-05-08 | 3 | -223/+2 |
| | | | | fixes handling of word-replace and removes tool/update. | ||||
* | Made comment a little more detailed. | Joel Sherrill | 2000-05-08 | 1 | -1/+2 |
* | Updated. | Joel Sherrill | 2000-05-08 | 1 | -17/+4 |
* | Added Data Types chapter. | Joel Sherrill | 2000-05-08 | 2 | -2/+4 |
* | New file datatypes.texi added. | Joel Sherrill | 2000-05-08 | 1 | -0/+1 |
* | Added Data Types Chapter. | Joel Sherrill | 2000-05-08 | 2 | -3/+10 |
* | Fixed typo so constand would have "RTEMS_". | Joel Sherrill | 2000-05-08 | 1 | -1/+1 |
* | Added function index entries for all data types and enhanced introductory | Joel Sherrill | 2000-05-08 | 1 | -3/+85 |
| | | | | structure. | ||||
* | Fixed type so constant would have "RTEMS_" in front of it. | Joel Sherrill | 2000-05-08 | 1 | -1/+1 |
* | Now sharing the "buildrt.t" or Building RTEMS chapter with the | Joel Sherrill | 2000-05-08 | 2 | -142/+4 |
| | | | | C version of Getting Started. | ||||
* | New file. | Joel Sherrill | 2000-05-05 | 1 | -0/+229 |
* | Updated example. | Joel Sherrill | 2000-05-05 | 1 | -56/+18 |
* | Added function indexes for CONFIGURE_ constants. | Joel Sherrill | 2000-05-05 | 1 | -1/+85 |
* | More updates. | Joel Sherrill | 2000-05-05 | 2 | -4/+4 |
* | Added much information on confdefs.h parameters. | Joel Sherrill | 2000-05-05 | 1 | -78/+437 |
* | Modifed to avoid using @uref directive since that does not seem | Joel Sherrill | 2000-05-04 | 3 | -19/+34 |
| | | | | to work with pdf generation. | ||||
* | More information on what symbolic information is for and | Joel Sherrill | 2000-05-04 | 1 | -0/+13 |
| | | | | how to get it from a file other thatn the executable. |
