path: root/doc (follow)
* Updated.Joel Sherrill2000-05-081-17/+4
* Added Data Types chapter.Joel Sherrill2000-05-082-2/+4
* New file datatypes.texi added.Joel Sherrill2000-05-081-0/+1
* Added Data Types Chapter.Joel Sherrill2000-05-082-3/+10
* Fixed typo so constand would have "RTEMS_".Joel Sherrill2000-05-081-1/+1
* Added function index entries for all data types and enhanced introductoryJoel Sherrill2000-05-081-3/+85
| | | | structure.
* Fixed type so constant would have "RTEMS_" in front of it.Joel Sherrill2000-05-081-1/+1
* Now sharing the "buildrt.t" or Building RTEMS chapter with theJoel Sherrill2000-05-082-142/+4
| | | | C version of Getting Started.
* New file.Joel Sherrill2000-05-051-0/+229
* Updated example.Joel Sherrill2000-05-051-56/+18
* Added function indexes for CONFIGURE_ constants.Joel Sherrill2000-05-051-1/+85
* More updates.Joel Sherrill2000-05-052-4/+4
* Added much information on confdefs.h parameters.Joel Sherrill2000-05-051-78/+437
* Modifed to avoid using @uref directive since that does not seemJoel Sherrill2000-05-043-19/+34
| | | | to work with pdf generation.
* More information on what symbolic information is for andJoel Sherrill2000-05-041-0/+13
| | | | how to get it from a file other thatn the executable.
* Added nextstep.texiJoel Sherrill2000-05-041-0/+1
* Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de>Joel Sherrill2000-05-0431-140/+508
| | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information.
* New file.Joel Sherrill2000-05-041-0/+72
* Patch rtemsdoc-4.5.0-rc-4-cvs.diff from Ralf CorsepiusJoel Sherrill2000-05-022-8/+31
| | | | | <corsepiu@faw.uni-ulm.de> to correct some typos and improve the information for DDD and the Hitachi SH.
* Modified to correct references to gmake per comment from Stephan WilmsJoel Sherrill2000-05-025-10/+17
| | | | <Stephan.Wilms@CWA.de>.
* RTEMS_MAKEFILE_PATH instructions incorrectly included rtems subdirectory.Joel Sherrill2000-05-021-2/+5
| | | | | This directory was removed post-4.0 to be more in compliance with GNU standards. Reported by Stephan Wilms <Stephan.Wilms@CWA.de>.
* A bit more explanation for task variables per Eric Norum <eric@cls.usask.ca>.Joel Sherrill2000-05-011-0/+7
* File rendered obsolete by rtemsdoc-4.5.0-rc-3.diff fromJoel Sherrill2000-05-011-342/+0
| | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* Removed file rendered obsolete by rtemsdoc-4.5.0-rc-3.diff fromJoel Sherrill2000-05-012-90/+1
* New file added by rtemsdoc-4.5.0-rc-3.diff fromJoel Sherrill2000-05-011-0/+1045
* Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill2000-05-0156-644/+595
| | | | | | | | | | | | | | | | | | | | | | | | | It addresses: * .cvsignore (only minor changes to yours, as they were pretty clean, most changes result from my mkcvsignore script being overly pedantic sorting entries alphabetically.) * timing.t handling and time<BSP>_.texi handling in supplements * network.t handling in bsp_howto * RTEMS_DATE and RTEMS_UPDATE handling in configure.in. [It actually is a hack, as we could apply automake's version.texi handling instead - I know think to understand what automake does with it.] * avoid using temporary files; Therefore a new tool called bmenu2, derived from bemenu, is introduced, which reads a single file from stdin and writes to stdio. To apply: cd rtemsdoc patch -p1 < rtemsdoc-4.5.0-rc-3.diff cvs rm -f bsp_howto/network.t cvs add tools/bmenu/bmenu2.c ./bootstrap BTW: word-replace now is unused. It could be removed if you like to.
* Updated.Joel Sherrill2000-04-271-0/+13
* New files. First attempt.Joel Sherrill2000-04-2741-0/+861
* Updated.Joel Sherrill2000-04-271-13/+24
* Removed -- temporary files.Joel Sherrill2000-04-278-11515/+0
* Files moved around and missed in the previous commit.Joel Sherrill2000-04-2711-0/+14
* Modified to give rpm removal command instead of install command again.Joel Sherrill2000-04-271-6/+6
* Patches rtemsdoc-4.5.0-rc.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-04-267-40/+50
| | | | | | | | | | | | | that addresses the following: The patch below should * fix the *pdf cleanup handling * fix dependencies between pdf-documents and texi-files It also contains an attempt to let networking/schedule.t use states.pdf instead of ascii graphics, but though each pdf image looks nice, it comes out weirdly distorted in the main pdf document.
* Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-04-26135-13751/+18326
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
* Merged changes from 4.5 branch and removed that branch.Joel Sherrill2000-04-2511-49/+154
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Added instructions on running ttcp from Eric Norum <eric@cls.usask.ca>.Joel Sherrill2000-03-241-0/+37
* Eric Norum spotted this sentence where it said preemption had to beJoel Sherrill2000-02-291-1/+3
| | | | disabled for timeslicing to happen. This was wrong.
* Changed to 4.5.0-beta1b.Joel Sherrill2000-02-232-6/+6
* Added a comment.Joel Sherrill2000-02-231-0/+4
* New file.Joel Sherrill2000-02-231-0/+368
* Adding information on prebuilt toolset binaries.Joel Sherrill2000-02-226-34/+72
* New file.Joel Sherrill2000-02-221-0/+48
* Fixed typo.Joel Sherrill2000-02-181-1/+1
* Patch from Eric Norum <eric@cls.usask.ca> to include some informationJoel Sherrill2000-02-181-0/+8
| | | | on simple binary semaphores.
* Added note from Ian Lance Taylor <ian@zembu.com>.Joel Sherrill2000-01-271-2/+6
* Added rtems_task_variable_get from Eric Norum.Joel Sherrill2000-01-231-1/+48
* Updated to reflect changing to void * on task variables byJoel Sherrill2000-01-231-8/+10
* Documentation to reflect patch from Eric Norum <eric@cls.usask.ca> toJoel Sherrill2000-01-211-2/+11
| | | | | the network initialization enhancement request by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>.
* Added POSIX interpretation subsection and updated status.Joel Sherrill2000-01-132-4/+16
| | | | | The message queue manager chapter needs to be updated to reflect completion of the implementation.
