* bsp_howto/timer.t: Eliminate uses of old benchmark timer names.
* setup.def, started/buildc.t: Update.
* bsp_howto/BSPInitFlowchart-49.png: Update figure.
* user/conf.t: Add CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM and
CONFIGURE_APPLICATION_DISABLE_FILESYSTEM.
* shell/rtems.t, user/conf.t, user/stackchk.t: Rename STACK_CHECKER_ON
to more appropriate CONFIGURE_STACK_CHECKER_ENABLED.
* user/conf.t: Fix typo.
* user/conf.t: Add support for optionally having a unified work area.
In other words, the RTEMS Workspace and C Program Heap are the same
pool of memory.
* bsp_howto/Developer-User-Timeline.png: Correct figure.
* user/chains.t, user/conf.t, user/object.t, user/userext.t:
More "bool" cleanup.
* bsp_howto/ata.t, bsp_howto/rtc.t, networking/networkapp.t,
user/chains.t, user/stackchk.t: Convert to "bool".
* user/datatypes.t: Add deprecation notices to
"rtems_boolean", "rtems_single", "rtems_double".
* user/intr.t, user/userext.t: Convert to "bool".
* bsp_howto/timer.t: Update documentation to reflect Timer Driver
renaming.
* bsp_howto/clock.t: The Shared Memory Driver no longer requires the
special IOCTL in Clock_control. This was a hack which has existed
since before the Classic API Timer Manager was implemented. All
implementations of and references to Clock_control were removed.
* user/conf.t: Add CONFIGURE_BSP_PREREQUISITE_DRIVERS and
CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS.
* user/object.t: Correct order of arguments.
* user/clock.t: Correct discussion of timeval.
* bsp_howto/init.t: Eliminate empty section.
* bsp_howto/init.t: Complete update.
* bsp_howto/Makefile.am, bsp_howto/init.t, bsp_howto/intro.t,
bsp_howto/makefiles.t, bsp_howto/support.t: Update initialization
sequence. Add another figure.
* bsp_howto/BSPInitFlowchart-49.eps, bsp_howto/BSPInitFlowchart-49.png: New files.
* index.html.in: Reorder manuals.
* bsp_howto/Makefile.am, bsp_howto/linkcmds.t, bsp_howto/makefiles.t,
bsp_howto/target.t: Update some of this manual.
* bsp_howto/Developer-User-Timeline.eps,
bsp_howto/Developer-User-Timeline.png: New files.
* bsp_howto/ata.t, bsp_howto/clock.t, bsp_howto/ide-ctrl.t,
bsp_howto/nvmem.t, bsp_howto/shmsupp.t, user/datatypes.t, user/mp.t,
user/userext.t: Eliminate all references to rtems_signedXX and
rtems_unsignedXX.
* user/msg.t, user/sem.t, user/task.t: Update to new parameter types.
Emphasize that you can use a pointer for task arguments.
* user/datatypes.t: Add rtems_name. Add comment about
rtems_task_argument changing from simple unsigned thirty two bit
integer to being derived from a C99 uintptr_t in 4.8 and newer.
PR 1263/doc
* user/part.t: Improve discussion of alignment and minimum buffer
sizes.
PR 1288/doc
* user/intr.t: Update callable from ISR section.
* user/msg.t: Parameter is size not count. Spotted by Sebastian Huber.
* porting/idlethread.t: Correct prototype of Idle threads.
PR 1291/cpukit
* posix_users/semaphores.t: Update to reflect absolute time.
* shell/Makefile.am, shell/rtems.t: Add pthread command.
* posix_users/mutex.t: Add ETIMEDOUT.
* shell/confinit.t: New argument sequence for rtems_shell_init().
* user/barrier.t, user/clock.t, user/dpmem.t, user/msg.t, user/part.t,
user/region.t, user/rtmon.t, user/sem.t, user/task.t, user/timer.t:
Correct documentation typos noticed and thankfully reported by
Fabrício de Novaes Kucinskis <fabricio@dea.inpe.br>
* user/.cvsignore: Add chains.texi.
* doc/user/chains.t: New.
* doc/ada_user/ada_user.texi, doc/user/Makefile.am,
doc/user/c_user.texi, doc/user/dirstat.texi: Updated for the
chains documentation.
* user/io.t: Fix typos for IO unregister reported by Catalin Morosan
<catalin.morosan at gmail.com>.
* user/conf.t: Add CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS.
* user/conf.t: Add CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION and
CONFIGURE_MAXIMUM_PRIORITY.
* user/conf.t: Add CONFIGURE_MINIMUM_STACK_SIZE.
* user/bsp.t, user/conf.t, user/task.t: Add ability for application to
configure minimum stack size. Add RTEMS_CONFIGURED_MINIMUM_STACK_SIZE
constant so user can clearly indicate they want the configured as
opposed to the recommended minimum stack size.
* started/buildc.t: Add paragraph on see CVS for latest patches.
* user/conf.t: Add CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE and example
of how to compute message CONFIGURE_MESSAGE_BUFFER_MEMORY using it.
* user/rtmon.t: Change to using new types.
* cpu_supplement/.cvsignore, cpu_supplement/Makefile.am,
cpu_supplement/arm.t, cpu_supplement/bfin.t,
cpu_supplement/cpu_supplement.texi, cpu_supplement/i386.t,
cpu_supplement/m68k.t, cpu_supplement/mips.t,
cpu_supplement/powerpc.t, cpu_supplement/preface.texi,
cpu_supplement/sh.t: Remove duplicated text from each CPU specific
chapter. This text was necessary when each CPU was a separate manual
but now only needs to be one place and that is in an introductory
chapter.
* cpu_supplement/general.t: New file.
* user/bsp.t, user/init.t: Rework initialization and BSP chapters to
account for changes to initialization framework.
* user/conf.t: Add baseline interface for Watchdog Driver.
