closes #2812.
* user/barrier.t, user/clock.t, user/dpmem.t, user/msg.t, user/part.t,
user/region.t, user/rtmon.t, user/sem.t, user/task.t, user/timer.t:
Correct documentation typos noticed and thankfully reported by
FabrÃcio de Novaes Kucinskis <fabricio@dea.inpe.br>
* user/bsp.t, user/conf.t, user/init.t, user/intr.t, user/overview.t,
user/timer.t: Correct default values. Make it clear that confdefs.h
calculates the memory required for you.
* user/barrier.t, user/clock.t, user/concepts.t, user/conf.t,
user/datatypes.t, user/dpmem.t, user/fatal.t, user/init.t, user/mp.t,
user/msg.t, user/part.t, user/region.t, user/rtmon.t, user/sem.t,
user/task.t, user/timer.t: Corrected various errors in the
documentation.
* user/barrier.t, user/clock.t, user/concepts.t, user/cpuuse.t,
user/init.t, user/intr.t, user/io.t, user/mp.t, user/rtmon.t,
user/sem.t, user/stackchk.t, user/task.t, user/timer.t: Updated the
Ada documentation to reflect the current binding.
PR 1171/doc
* user/timer.t: Correct documentation for rtems_timer_initiate_server.
PR 618/rtems
* user/clock.t, user/dpmem.t, user/event.t, user/msg.t, user/part.t,
user/region.t, user/sem.t, user/task.t, user/timer.t: Add NULL
checks.
* timer.t: Added task-based timer information including the
new directives rtems_timer_initiate(), rtems_timer_server_fire_after(),
and rtems_timer_server_fire_when().
including a new section in the Getting Started called "Where to
Go From Here", lots of index entries added, and more configuration
table information.
blows up both makeinfo and texi2dvi. So I have commented them out.
to be correct in either C or Ada.
Added the interrupt disable, enable, flash, and is in progress directives.
changed "97" to "1997"
