PR 1793/doc
* .cvsignore, Makefile.am, README, configure.ac, index.html.in,
main.am, project.am, ada_user/.cvsignore, ada_user/ada_user.texi,
ada_user/example.texi, bsp_howto/.cvsignore,
bsp_howto/bsp_howto.texi, cpu_supplement/.cvsignore,
cpu_supplement/cpu_supplement.texi, cpu_supplement/preface.texi,
develenv/.cvsignore, develenv/develenv.texi, develenv/intro.texi,
filesystem/.cvsignore, filesystem/filesystem.texi,
filesystem/preface.texi, networking/.cvsignore,
networking/networking.texi, networking/preface.texi,
porting/.cvsignore, porting/porting.texi, porting/preface.texi,
posix1003.1/.cvsignore, posix1003.1/posix1003_1.texi,
posix_users/.cvsignore, posix_users/posix_users.texi,
posix_users/preface.texi, shell/.cvsignore, shell/preface.texi,
shell/shell.texi, started/.cvsignore, started/started.texi,
user/.cvsignore, user/c_user.texi, user/dirstat.texi,
user/example.texi, user/glossary.texi, user/preface.texi: Convert
from texi2www to texi2html.
* texi2html_init.in: New file.
* rtems_footer.html.in, rtems_header.html.in: Removed.
* user/.cvsignore: Add semaphore_attributes.pdf.
* user/.cvsignore: Add Object ID PDF files.
* user/.cvsignore: Add chains.texi.
* user/.cvsignore, user/Makefile.am, user/c_user.texi, user/concepts.t,
user/conf.t, user/dirstat.texi, user/stackchk.t, user/task.t,
user/userext.t: Add new Object Services collection. Tidy up some
configuration documentation from earlier changes.
* user/object.t: New file.
* user/.cvsignore, user/cpuuse.t, user/stackchk.t: Stack checker and
CPU usage chapters are now OK in the manual.
* user/.cvsignore: Update.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
