* | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-29 | 1 | -88/+0 |
| | | | | | | | | | | | * supplements/Makefile.am: i960 obsoleted. * supplements/i960/.cvsignore, supplements/i960/CVME961_TIMES, supplements/i960/ChangeLog, supplements/i960/Makefile.am, supplements/i960/bsp.t, supplements/i960/callconv.t, supplements/i960/cpumodel.t, supplements/i960/cputable.t, supplements/i960/fatalerr.t, supplements/i960/i960.texi, supplements/i960/intr_NOTIMES.t, supplements/i960/memmodel.t, supplements/i960/preface.texi, supplements/i960/timeCVME961.t: Removed. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Patch rtems-rc-4.5.0-21.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-06-10 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which splits the current monolithic specs files into a sequence of subparts. These can be concatenated togather to make a the whole .spec file. This cleans up the maintenance problem of having "all languages" and a "C/C++ only" gccnewlib spec files. Plus it should make it easier to produce variants like the gdb-m68k-bdm which require special hackery. :) Ralf's comments: It addresses the way *.spec.in get composed inside of the source tree. Changes: * Each spec.in is broken into several files (*.add), one *.add file per sub-package. * Each Makefile.am composes spec.ins from the *.add files * Removal of redundant automake support files. * Default value for BuildRoot changed to /tmp/<spec-file-name> * %clean stage added to *specs Advantages (IMHO). * The *.add files are easier to adminstrate and more flexible in comparison to the former *.specs.ins. * gccnewlib_c_only.spec.in now is composed from the same sources as gccnewlib.spec.in (less errors) * If using the default BuildRoot --clean now deletes all files that were generated while building. Notes: * rtems.spec.in has not yet been adapted to the scheme used for the other *spec.ins * Except for cosmetical changes the internals of the *.spec files should not have changed. To Apply: cvs rm -f scripts/binutils/binutils.spec.in cvs rm -f scripts/gccnewlib/gccnewlib.spec.in cvs rm -f scripts/gccnewlib/gccnewlib_c_only.spec.in cvs rm -f scripts/gdb/gdb.spec.in cvs rm -f scripts/config.sub cvs rm -f scripts/config.guess cvs rm -f scripts/install-sh cvs rm -f scripts/mkinstalldirs cvs rm -f scripts/missing patch -p1 < rtems-rc-4.5.0-21.diff cvs add scripts/*/*.add cvs add scripts/*/README | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Much renamed, most stuff automatically generated now. | Joel Sherrill | 1998-10-19 | 1 | -44/+1 |
* | Makefiles in much better shape even though not all files have automatically | Joel Sherrill | 1998-10-19 | 1 | -1/+1 |
| | | | | generated menus yet. | ||||
* | Switched from presenting timing data based on CPU models to presenting it | Joel Sherrill | 1998-08-13 | 1 | -25/+25 |
| | | | | based on board model. | ||||
* | Corrected paths after moving all supplements into a subdirectory. | Joel Sherrill | 1998-04-11 | 1 | -1/+1 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 1 | -1/+1 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+8 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 1 | -0/+123 |
