* | 2010-12-16 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-12-16 | 1 | -57/+0 |
| | | | | | | | | | * develenv/direct.t: Remove Getting Started with GNAT/RTEMS. * started_ada/.cvsignore, started_ada/Makefile.am, started_ada/buildada.t, started_ada/gdb.t, started_ada/intro.t, started_ada/require.t, started_ada/sample.t, started_ada/stamp-vti, started_ada/started_ada.texi, started_ada/tversions.texi, started_ada/version.texi: Removed. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Merged changes from 4.5 branch and removed that branch. | Joel Sherrill | 2000-04-25 | 1 | -2/+5 |
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Changed arc to archive. | Joel Sherrill | 1998-04-14 | 1 | -1/+1 |
| | | | | Switched self-maintaining ASCII tree picture. | ||||
* | Now a passable Ada manual | Joel Sherrill | 1998-04-11 | 1 | -19/+14 |
* | Base line -- copied from C/C++ | Joel Sherrill | 1998-04-11 | 1 | -0/+59 |
