* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -31/+0 |
* | 2011-12-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-06 | 1 | -2/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | PR 1793/doc * .cvsignore, Makefile.am, README, configure.ac, index.html.in, main.am, project.am, ada_user/.cvsignore, ada_user/ada_user.texi, ada_user/example.texi, bsp_howto/.cvsignore, bsp_howto/bsp_howto.texi, cpu_supplement/.cvsignore, cpu_supplement/cpu_supplement.texi, cpu_supplement/preface.texi, develenv/.cvsignore, develenv/develenv.texi, develenv/intro.texi, filesystem/.cvsignore, filesystem/filesystem.texi, filesystem/preface.texi, networking/.cvsignore, networking/networking.texi, networking/preface.texi, porting/.cvsignore, porting/porting.texi, porting/preface.texi, posix1003.1/.cvsignore, posix1003.1/posix1003_1.texi, posix_users/.cvsignore, posix_users/posix_users.texi, posix_users/preface.texi, shell/.cvsignore, shell/preface.texi, shell/shell.texi, started/.cvsignore, started/started.texi, user/.cvsignore, user/c_user.texi, user/dirstat.texi, user/example.texi, user/glossary.texi, user/preface.texi: Convert from texi2www to texi2html. * texi2html_init.in: New file. * rtems_footer.html.in, rtems_header.html.in: Removed. | ||||
* | Remove EDITION (Unused) | Ralf Corsepius | 2010-06-11 | 1 | -2/+0 |
* | 2006-10-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-10-25 | 1 | -1/+11 |
| | | | | | * posix_users/.cvsignore, rgdb_specs/.cvsignore, rtems_gdb/.cvsignore, started/.cvsignore, started_ada/.cvsignore: Add more generated files. | ||||
* | Provoke cvs complaints on generated docs. | Ralf Corsepius | 2006-01-19 | 1 | -8/+0 |
* | Cleanup. | Ralf Corsepius | 2004-02-13 | 1 | -1/+0 |
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 1 | -0/+2 |
| | | | | | | * .cvsignore, binaries.t, buildc.t, buildrt.t, intro.t, nextstep.t, nt.t, started.texi: Merge from branch. * tversions.texi.in: New file. | ||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 1 | -5/+7 |
| | | | | | | | | * version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -0/+2 |
| | | | | * .cvsignore: Added rtems_header.html and rtems_footer.html. | ||||
* | Patch rtemsdoc-4.5.0-rc-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-06-01 | 1 | -1/+2 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Ralf's comments follow: Changes: * Enhanced versioning: - Addition of automake's version.texi support - Replacement of rtemsdoc's former versioning support by automake's versioning support (Abandoning RTEMS-UPDATE-* etc.) - Abandoning setup.texi.in - Add EDITION to each documents Makefile.am - version.texi support in project.am - Addition of maintainer mode (currently only used to prevent incorrectly updating timestamps when users touch automake's version.texi timestamp files (stamp-vti)). * Fixing info dir support - Use texinfo's @dircategory and @direntry instead of infos *-DIR-ENTRY - $(infodir)/dir is now correctly set up * Avoid using temporary files - Pipe texts through REPLACE2 into BMENU2 instead of using temporary files. - Abandon using bmenu in favor of bmenu2 (bmenu could be removed now) * Prepare Makefile.ams for building in a separate buildtree - prefix files with $(srcdir) in Makefile.am for files which must be generated inside of the source tree Notes: * rtemsdoc can not yet be build in a separate source-tree, but we are very close to it. * You as the maintainer of this package now should always use --enable-maintainer-mode to configure rtemsdoc. | ||||
* | Added start-? | Joel Sherrill | 2000-05-28 | 1 | -0/+1 |
* | Added nextstep.texi | Joel Sherrill | 2000-05-04 | 1 | -0/+1 |
* | Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 2000-05-01 | 1 | -9/+9 |
| | | | | | | | | | | | | | | | | | | | | | | | | | It addresses: * .cvsignore (only minor changes to yours, as they were pretty clean, most changes result from my mkcvsignore script being overly pedantic sorting entries alphabetically.) * timing.t handling and time<BSP>_.texi handling in supplements * network.t handling in bsp_howto * RTEMS_DATE and RTEMS_UPDATE handling in configure.in. [It actually is a hack, as we could apply automake's version.texi handling instead - I know think to understand what automake does with it.] * avoid using temporary files; Therefore a new tool called bmenu2, derived from bemenu, is introduced, which reads a single file from stdin and writes to stdio. To apply: cd rtemsdoc patch -p1 < rtemsdoc-4.5.0-rc-3.diff cvs rm -f bsp_howto/network.t cvs add tools/bmenu/bmenu2.c ./bootstrap BTW: word-replace now is unused. It could be removed if you like to. | ||||
* | New files. First attempt. | Joel Sherrill | 2000-04-27 | 1 | -0/+25 |
