* configure.ac, index.html.in: mips64orion port removed as mips port
more completely covers the MIPS family.
* rtems_support.html.in: Removed.
* configure.ac: Merger from rtems-4-6-branch.
Purge hppa1.1.
* index.html.in: Purge hppa1.1.
* project.am: Merger from rtems-4-6-branch.
* rtems_support.html.in: Purge hppa1.1.
* HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in,
rtems_support.html.in, ada_user/ada_user.texi: Merge from branch.
* acinclude.m4, images/rtems_logo.jpg: New files.
* SUPPORT, tools/texi2www/archive/texi2www-960103.tgz: Removed.
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
