* | 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-05 | 1 | -81/+0 |
| | | | | | | | | * ChangeLog: Merge-in posix_users/ChangeLog. * ChangeLog: Merge-in posix1003.1/ChangeLog. * ChangeLog: Merge-in itron3.0/ChangeLog. * posix_users/ChangeLog, posix1003.1/ChangeLog, itron3.0/ChangeLog: Remove. | ||||
* | 2004-01-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-01-09 | 1 | -0/+7 |
| | | | | | | | PR 464/doc * clock.t, signal.t: Add documentation for usleep() and ualarm(). Also fixed a couple of calls which have the wrong .h files per the OpenGroup site documentation. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -0/+4 |
| | | | | * Makefile.am: Cosmetics. | ||||
* | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-11 | 1 | -0/+4 |
* | 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-26 | 1 | -0/+5 |
| | | | | | * Makefile.am: Add *.info to CLEANFILES to accomodate automake-1.7f/1.8 breaking building infos. | ||||
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 1 | -0/+4 |
| | | | | * Makefile.am: Merger from rtems-4-6-branch. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 1 | -0/+4 |
| | | | | * posix_users.texi: Merge from branch. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 1 | -0/+5 |
| | | | | | PR 466/doc * io.t: Added sync(). | ||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 1 | -0/+4 |
| | | | | * posix_users.texi: Set @setfilename posix_users.info. | ||||
* | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-24 | 1 | -0/+4 |
| | | | | * Makefile.am: Put GENERATED_FILES into $builddir. | ||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 1 | -0/+8 |
| | | | | | | | | * version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort. | ||||
* | 2003-01-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-21 | 1 | -0/+4 |
| | | | | * stamp-vti, version.texi: Regenerated. | ||||
* | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-13 | 1 | -0/+4 |
* | 2002-10-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-24 | 1 | -0/+4 |
* | 2001-06-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-06-28 | 1 | -0/+5 |
| | | | | | | * preface.texi, procenv.t, process.t, signal.t, stamp-vti, version.texi: Updated as part of starting a sweep on the POSIX User's Guide. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -0/+4 |
| | | | | * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-18 | 1 | -0/+4 |
| | | | | * Makefile.am: include main.am, require automake-1.5. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -0/+4 |
| | | | | * .cvsignore: Added rtems_header.html and rtems_footer.html. | ||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-25 | 1 | -0/+3 |
