* | Remove texinfo format documentation. Replaced by Sphinx formatted documentation. | Joel Sherrill | 2017-01-11 | 1 | -69/+0 |
| | | | | closes #2812. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -11/+14 |
* | Added Constants, Feature Flags, and Macros (included in Functions). | Joel Sherrill | 1998-03-18 | 1 | -1/+1 |
| | | | | No status information was included. | ||||
* | Completed status pass on functions and data types. | Joel Sherrill | 1998-03-17 | 1 | -1/+1 |
* | Completed first pass at function status. | Joel Sherrill | 1998-03-17 | 1 | -8/+13 |
| | | | | Added most data types without status information. | ||||
* | Added Function field. | Joel Sherrill | 1998-03-16 | 1 | -7/+7 |
* | Added functions from POSIX standard. | Joel Sherrill | 1998-03-14 | 1 | -0/+43 |
* | Outline complete and apparently correct. | Joel Sherrill | 1998-03-11 | 1 | -9/+9 |
* | Baseline | Joel Sherrill | 1998-03-11 | 1 | -0/+21 |
