* | Remove texinfo format documentation. Replaced by Sphinx formatted documentation. | Joel Sherrill | 2017-01-11 | 1 | -200/+0 |
| | | | | closes #2812. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 1 | -2/+2 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Added constants through ch13 | Joel Sherrill | 1998-04-02 | 1 | -39/+42 |
* | Added Constants, Feature Flags, and Macros (included in Functions). | Joel Sherrill | 1998-03-18 | 1 | -0/+57 |
| | | | | No status information was included. | ||||
* | Completed status pass on functions and data types. | Joel Sherrill | 1998-03-17 | 1 | -5/+5 |
* | Added function status and data types | Joel Sherrill | 1998-03-16 | 1 | -0/+8 |
* | Added Function field. | Joel Sherrill | 1998-03-16 | 1 | -30/+30 |
* | Function implmentation status information correct. | Joel Sherrill | 1998-03-16 | 1 | -10/+10 |
* | Added functions from POSIX standard. | Joel Sherrill | 1998-03-14 | 1 | -0/+103 |
* | Baseline | Joel Sherrill | 1998-03-11 | 1 | -0/+32 |
