* | 2007-05-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-05-15 | 1 | -294/+0 |
| | | | | | | | | | | | * Makefile.am, gen_section: Integrate Rate Monotonic Statistics and Period Usage into Rate Monotonic Manager. Added the following directives: rtems_rate_monotonic_get_statistics, rtems_rate_monotonic_reset_statistics, rtems_rate_montonic_reset_all_statistics, rtems_rate_montonic_report_statistics, and rtems_object_get_name. Obsoleted the rtems/rtmonuse.h file as a public interface. * rtmonuse.t: Removed. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | New files | Joel Sherrill | 1998-11-19 | 1 | -0/+294 |
