* | 2010-06-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-17 | 1 | -310/+0 |
| | | | | | | | | | | | | | | * Makefile.am, configure.ac, index.html.in, develenv/direct.t, posix_users/gen_size_report, started/nextstep.t, started_ada/buildada.t, user/conf.t, user/object.t: Remove ITRON API. * itron3.0/.cvsignore, itron3.0/Makefile.am, itron3.0/config.t, itron3.0/eventflags.t, itron3.0/fixedblock.t, itron3.0/gen_all, itron3.0/gen_section, itron3.0/gen_status_shell, itron3.0/interrupt.t, itron3.0/itron.texi, itron3.0/mailbox.t, itron3.0/memorypool.t, itron3.0/msgbuffer.t, itron3.0/network.t, itron3.0/preface.texi, itron3.0/rendezvous.t, itron3.0/semaphore.t, itron3.0/stamp-vti, itron3.0/status.t, itron3.0/task.t, itron3.0/tasksync.t, itron3.0/time.t, itron3.0/version.texi: Removed. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Added copyright. | Joel Sherrill | 1999-11-16 | 1 | -0/+4 |
* | Significantly cleaned up to make a much better starting point for the | Joel Sherrill | 1999-06-04 | 1 | -26/+31 |
| | | | | class. | ||||
* | Made the gen_section more accurate. | Joel Sherrill | 1999-05-26 | 1 | -27/+27 |
* | Prototypes are now based on how the TRON specification states them. | Joel Sherrill | 1999-05-26 | 1 | -9/+18 |
| | | | | The style in the output is not right but it is a good starting point. | ||||
* | Regenerated to include more information in the stub. Now they have | Joel Sherrill | 1999-05-26 | 1 | -19/+19 |
| | | | | the descriptive titles. | ||||
* | Corrected error code section. | Joel Sherrill | 1999-05-26 | 1 | -18/+0 |
* | Replaced error code section. | Joel Sherrill | 1999-05-26 | 1 | -27/+9 |
* | Initial revision | Joel Sherrill | 1999-05-20 | 1 | -0/+328 |
