path: root/doc/itron3.0/preface.texi (follow)
* 2010-06-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-06-171-14/+0
| | | | | | | | | | | | | | * Makefile.am, configure.ac, index.html.in, develenv/direct.t, posix_users/gen_size_report, started/nextstep.t, started_ada/buildada.t, user/conf.t, user/object.t: Remove ITRON API. * itron3.0/.cvsignore, itron3.0/Makefile.am, itron3.0/config.t, itron3.0/eventflags.t, itron3.0/fixedblock.t, itron3.0/gen_all, itron3.0/gen_section, itron3.0/gen_status_shell, itron3.0/interrupt.t, itron3.0/itron.texi, itron3.0/mailbox.t, itron3.0/memorypool.t, itron3.0/msgbuffer.t, itron3.0/network.t, itron3.0/preface.texi, itron3.0/rendezvous.t, itron3.0/semaphore.t, itron3.0/stamp-vti, itron3.0/status.t, itron3.0/task.t, itron3.0/tasksync.t, itron3.0/time.t, itron3.0/version.texi: Removed.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-1/+1
* New file.Joel Sherrill1999-11-161-0/+14
