closes #2812.
* bsp_howto/ata.t, bsp_howto/clock.t, bsp_howto/ide-ctrl.t,
bsp_howto/nvmem.t, bsp_howto/shmsupp.t, user/datatypes.t, user/mp.t,
user/userext.t: Eliminate all references to rtems_signedXX and
rtems_unsignedXX.
* ide-ctrl.t: Merger from 4.6-branch.
* ata.t, ide-ctrl.t: New file.
* .cvsignore: Added new .texi files.
* Makefile.am:: Added new files to generate.
* bsp_howto.texi: Added new chapters.
