closes #2812.
This patch adds the initial version of the SMP chapter to the Users Guide.
for details.
Adds documentation on the scheduler options and scheduler selection
to the User's Manual to reflect changes made in the development of
pluggable scheduling with EDF and CBS schedulers.
* project.am (MOSTLYCLEANFILES): Remove index.html.
* ada_user/Makefile.am (CLEANFILES): Fixup image handling.
* ada_user/Makefile.am: Add ObjectId pdf files.
* ada_user/Makefile.am, ada_user/ada_user.texi, user/Makefile.am,
user/c_user.texi, user/concepts.t, user/overview.t,
user/preface.texi, user/schedule.t, user/sem.t: Add table of figures.
Add text and graphic of tree illustrating valid combinations of
semaphore attributes.
* user/semaphore_attributes.eps, user/semaphore_attributes.png:
New files.
* ada_user/Makefile.am: Fix typo.
* ada_user/Makefile.am, user/Makefile.am, user/concepts.t: Add 16 bit
object Id format information.
* user/ObjectId-16Bits.eps, user/ObjectId-16Bits.png: New files.
* ada_user/Makefile.am: Make Ada manual build again after adding
figure.
* ada_user/Makefile.am, ada_user/ada_user.texi: Now builds.
* ada_user/Makefile.am, ada_user/ada_user.texi: Ada API manual now
builds again.
cpu_supplement/Makefile.am, cpu_supplement/cpu_supplement.texi,
cpu_supplement/sparc.t: Add Blackfin CPU supplement chapter and get
everything building from previous breakages.
* cpu_supplement/bfin.t: New file.
* Makefile.am: Cosmetics.
* Makefile.am: Removed GENERATED_FILES from list of TEXINFOS.
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
that addresses the following:
The patch below should
* fix the *pdf cleanup handling
* fix dependencies between pdf-documents and texi-files
It also contains an attempt to let networking/schedule.t use states.pdf
instead of ascii graphics, but though each pdf image looks nice, it
comes out weirdly distorted in the main pdf document.
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
