* libnetworking/Makefile.am: Add -D_KERNEL to CPPFLAGS.
* libnetworking/net/bpf.h: Partial update from FreeBSD.
* libnetworking/sys/sysctl.h: Partial update from FreeBSD.
* libnetworking/kern/kern_sysctl.c: Partial update from FreeBSD.
* libfs/src/imfs/imfs_debug.c, libfs/src/imfs/memfile.c:
Use fprintf(stdout,...) instead of printf.
* libblock/src/ide_part_table.c: Use fprintf(stdout,...) instead of
printf.
* libmisc/capture/capture-cli.c, libmisc/cpuuse/cpuuse.c,
libmisc/dumpbuf/dumpbuf.c, libmisc/fsmount/fsmount.c,
libmisc/monitor/mon-command.c, libmisc/monitor/mon-config.c,
libmisc/monitor/mon-dname.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-extension.c, libmisc/monitor/mon-itask.c,
libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-mpci.c,
libmisc/monitor/mon-object.c, libmisc/monitor/mon-prmisc.c,
libmisc/monitor/mon-queue.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/mon-task.c, libmisc/rtmonuse/rtmonuse.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c, libmisc/shell/shell.h,
libmisc/stackchk/check.c, libmisc/untar/untar.c: Use
* sapi/include/rtems/sptables.h: Remove _RTEMS_version.
* rtems/score/i386.h: Rename i386_swap_U* to i386_swap_u* (API
consistency with other ports).
* libcsupport/Makefile.am: Install include_sys_HEADERS for NEWLIB
only. Merge sys/cdefs.h into general include_sys_HEADERS.
PR 605/bsps
* cpu.c: Remove further c++ style comments having been missed in
previous patch. Remove printf's entirely.
* rtems/include/rtems/rtems/types.h: Include <rtems/stdint.h>
instead of <stdint.h>.
Conditionally typedef rtems*signed64 types.
* score/include/rtems/system.h: Include <rtems/stdint.h> instead of
<stdint.h>.
* configure.ac: Rework stdint.h/inttypes.h support.
Add RTEMS_USES_STDINT_H. Add RTEMS_USES_INTTYPES_H.
Remove NEED_STDINT_H. Remove NEED_INTTYPES_H.
Remove termios-flag detection.
* libcsupport/Makefile.am: Install include/stdint.h and
include/inttypes.h for NEWLIB only.
* libcsupport/include/stdint.h: Rework; Now newlib specific.
* libcsupport/src/termios.c: Make newlib specific.
* include/rtems/stdint.h: Rework; Now wrapper to <stdint.h>.
* asm.h: New (stub file. For consistency with other ports, only).
* Makefile.am: Add asm.h.
* asm.h: Include rtems/score/powerpc.h instead of
rtems/score/ppc.h.
* rtems/score/powerpc.h: New (Copied and renamed from rtems/score/ppc.h)
for consistency with other ports.
* rtems/score/ppc.h: Deprecation wrapper to rtems/score/powerpc.h.
* rtems/score/cpu.h: Include rtems/score/powerpc.h instead of
rtems/score/ppc.h.
* asm.h, rtems/new-exceptions/cpu.h, rtems/score/ppc.h: addition of
MPC555 support as part of the addition of the SS555 BSP.
* rtems/score/cpu.h: Remove defining _POSIX_C_SOURCE for solaris.
* acinclude.m4 (RTEMS_CPUOPT): Use AC_DEFINE_UNQUOTED.
* backward/motorola/mc68681.h, backward/motorola/mc68230.h,
backward/zilog/z8536.h, backward/zilog/z8036.h,
backward/zilog/z8030.h: New.
* Makefile.am: Reflect having added new files above.
PR 605/bsps
* cpu.c: Do not use C++ style comments.
* rtems/score/cpu.h: Fix typo.
* cpu_asm.S: Convert asm comments to C-comments to prevent gcc-3.4.0pre
from choking on them.
* wrapup/Makefile.am: Add libblock for !UNIX only.
* libblock/Makefile.am: Build libblock for !UNIX only.
* libcsupport/Makefile.am: Build $(TERMIOS_C_FILES) for !UNIX only.
* libblock/Makefile.am: Remove LIBC_DEFINES (Unsupported).
* libfs/Makefile.am: Remove LIBC_DEFINES (Unsupported).
* Makefile.am: Remove LIBC_DEFINES (Unsupported).
* libcsupport/Makefile.am: Install sys/ioccom.h for NEWLIB only.
* libcsupport/Makefile.am: Remove $(LIBC_DEFINES) (Unsupported).
Install motorola-headers to $(includedir)/rtems/motorola.
Install zilog-header $(includedir)/rtems/zilog.
