* | This commit was generated by cvs2svn to compensate for changes in r25214, | Ralf Corsepius | 2011-03-18 | 4 | -8/+8 |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | ||||
| * | Import from zlib-1.2.5 | Ralf Corsepius | 2011-03-18 | 17 | -85/+227 |
* | | This commit was generated by cvs2svn to compensate for changes in r25212, | Ralf Corsepius | 2011-03-18 | 1 | -2/+2 |
|\| | | | | | which included commits to RCS files with non-trunk default branches. | ||||
| * | Import from zlib-1.2.5 | Ralf Corsepius | 2011-03-18 | 5 | -20/+20 |
| * | Import from zlib-1.2.5 | Ralf Corsepius | 2011-03-18 | 2 | -20/+21 |
| * | Import from zlib-1.2.5 | Ralf Corsepius | 2011-03-18 | 2 | -48/+35 |
* | | This commit was generated by cvs2svn to compensate for changes in r25208, | Ralf Corsepius | 2011-03-18 | 2 | -18/+42 |
| * | Import from zlib-1.2.5 | Ralf Corsepius | 2011-03-18 | 4 | -36/+74 |
| * | Import from zlib-1.2.5 | Ralf Corsepius | 2011-03-18 | 1 | -2/+7 |
| * | Import from zlib-1.2.5 | Ralf Corsepius | 2011-03-18 | 1 | -1/+2 |
* | | 2010-04-09 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-18 | 2 | -2/+7 |
| | | | | | | | | | | * zconf.h: Regenerate by zlib's configure. Eliminate HAVE_UNISTD_H. Use Z_PREFIX. | ||||
* | | 2010-03-28 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-03-18 | 2 | -9/+4 |
| | | | | | | | | * zconf.h: Add include of config.h | ||||
* | | Make code match prototype to eliminate warnings. | Thomas Doerfler | 2011-03-18 | 7 | -4/+22 |
| | | | | | | | | eliminate unneeded comilation of 64 bit functions | ||||
* | | This commit was generated by cvs2svn to compensate for changes in r25198, | Ralf Corsepius | 2011-03-18 | 1 | -0/+0 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 4 | -506/+764 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 1 | -1/+1 |
| * | This commit was manufactured by cvs2svn to create branch 'zlib'. | cvs2git | 2011-03-18 | 6 | -0/+2084 |
| | | | | | | | | | | | | | | | | | | Cherrypick from master 2011-03-18 10:11:29 UTC Joel Sherrill <joel.sherrill@OARcorp.com> '2010-03-22 Joel Sherrill <joel.sherrill@oarcorp.com>': cpukit/zlib/doc/algorithm.txt cpukit/zlib/gzclose.c cpukit/zlib/gzguts.h cpukit/zlib/gzlib.c cpukit/zlib/gzread.c cpukit/zlib/gzwrite.c | ||||
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 2 | -40/+42 |
* | | 2010-03-22 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-03-18 | 28 | -2243/+4032 |
| | | | | | | | | | | | | | | | | | | | | * ChangeLog.zlib, FAQ, Makefile.am, README, adler32.c, compress.c, crc32.c, deflate.c, deflate.h, infback.c, inffast.c, inflate.c, inflate.h, inftrees.c, inftrees.h, trees.c, uncompr.c, zconf.h, zlib.3, zlib.h, zutil.c, zutil.h: Update to zlib 1.2.4. * gzclose.c, gzguts.h, gzlib.c, gzread.c, gzwrite.c, doc/algorithm.txt: New files. * algorithm.txt, gzio.c: Removed. | ||||
* | | This commit was generated by cvs2svn to compensate for changes in r25189, | Ralf Corsepius | 2011-03-18 | 2 | -0/+260 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 3 | -1/+536 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 2 | -208/+157 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 1 | -68/+411 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 1 | -92/+179 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 1 | -8/+14 |
* | | This commit was generated by cvs2svn to compensate for changes in r25183, | Ralf Corsepius | 2011-03-18 | 2 | -0/+64 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 3 | -26/+77 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 3 | -117/+250 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 1 | -8/+121 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 2 | -5/+36 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 1 | -48/+37 |
* | | This commit was generated by cvs2svn to compensate for changes in r25177, | Ralf Corsepius | 2011-03-18 | 1 | -0/+116 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 5 | -10/+126 |
* | | This commit was generated by cvs2svn to compensate for changes in r25175, | Ralf Corsepius | 2011-03-18 | 2 | -0/+834 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 3 | -47/+965 |
* | | This commit was generated by cvs2svn to compensate for changes in r25173, | Ralf Corsepius | 2011-03-18 | 3 | -0/+105 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 12 | -1134/+3162 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 2 | -6/+12 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 1 | -85/+197 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 1 | -4/+11 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 1 | -3/+1 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 1 | -4/+4 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 1 | -81/+139 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 1 | -15/+15 |
* | | This commit was generated by cvs2svn to compensate for changes in r25164, | Ralf Corsepius | 2011-03-18 | 1 | -12/+19 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 3 | -82/+120 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 1 | -9/+8 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 2 | -17/+30 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 1 | -9/+29 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2011-03-18 | 1 | -7/+26 |
