PR 618/rtems
* rtems/include/rtems/rtems/status.h, rtems/src/clockget.c,
rtems/src/clockset.c, rtems/src/dpmemcreate.c,
rtems/src/dpmemexternal2internal.c,
rtems/src/dpmeminternal2external.c, rtems/src/eventmp.c,
rtems/src/eventreceive.c, rtems/src/eventsend.c,
rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c,
rtems/src/msgqreceive.c, rtems/src/msgqsubmit.c,
rtems/src/partcreate.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/ratemoncancel.c,
rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, rtems/src/regioncreate.c,
rtems/src/regiondelete.c, rtems/src/regionextend.c,
rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c,
rtems/src/regionreturnsegment.c, rtems/src/semcreate.c,
rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c,
rtems/src/taskcreate.c, rtems/src/taskgetnote.c,
rtems/src/taskmode.c, rtems/src/taskrestart.c,
rtems/src/taskresume.c, rtems/src/tasksetnote.c,
rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c,
rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c,
rtems/src/taskwakewhen.c, rtems/src/timercreate.c,
rtems/src/timerfirewhen.c, rtems/src/timerserverfireafter.c,
rtems/src/timerserverfirewhen.c, score/include/rtems/score/object.h,
score/src/coretodvalidate.c, score/src/objectnametoid.c: Add NULL
checks.
* libnetworking/kern/kern_sysctl.c: sysctl_register_all cannot be
static with RTEMS.
* libnetworking/netinet/in.c: Partial update from FreeBSD.
* libnetworking/kern/kern_sysctl.c: Partial updates from FreeBSD.
* libnetworking/netinet/igmp_var.h: Cosmetic updates from FreeBSD.
* libnetworking/sys/sysctl.h: Update from FreeBSD.
* libnetworking/sys/socketvar.h: Update from FreeBSD.
* libnetworking/sys/protosw.h: More partial updates from FreeBSD.
* libnetworking/net/route.c: Reflect changes to radix.h.
* libnetworking/net/radix.h, libnetworking/net/radix.c: Partial
* libnetworking/sys/socket.h: Further update from FreeBSD
(Add sa_family_t).
* libnetworking/sys/protosw.h: Partial update from FreeBSD.
* libnetworking/sys/socket.h: Partial update from FreeBSD.
* libnetworking/rtems/rtems_syscall.c: Reflect changes to socket.h.
* libnetworking/kern/uipc_socket.c: Partial update from FreeBSD
(Remove adv-clause from copyright notice).
* libnetworking/netinet/igmp_var.h: Partial update from FreeBSD.
* libnetworking/net/bpf.h, libnetworking/net/if.h,
libnetworking/net/if_dl.h, libnetworking/net/if_ppp.h,
libnetworking/net/netisr.h, libnetworking/net/pppcompress.c,
libnetworking/net/radix.c, libnetworking/net/radix.h,
libnetworking/net/raw_cb.h, libnetworking/net/route.h,
libnetworking/netinet/icmp_var.h, libnetworking/netinet/if_ether.h,
libnetworking/netinet/igmp_var.h, libnetworking/netinet/in.h,
libnetworking/netinet/in_pcb.h, libnetworking/netinet/in_systm.h,
libnetworking/netinet/in_var.h, libnetworking/netinet/ip_fw.h,
libnetworking/netinet/ip_icmp.h, libnetworking/netinet/ip_mroute.h,
libnetworking/netinet/ip_var.h, libnetworking/netinet/tcp_debug.h,
libnetworking/netinet/tcp_seq.h, libnetworking/netinet/tcp_timer.h,
libnetworking/netinet/tcp_var.h, libnetworking/netinet/udp_var.h,
libnetworking/nfs/nfs.h, libnetworking/rtems/rtems_bsdnet.h,
libnetworking/rtems/rtems_bsdnet_internal.h,
libnetworking/sys/buf.h, libnetworking/sys/callout.h,
libnetworking/sys/conf.h, libnetworking/sys/domain.h,
libnetworking/sys/malloc.h, libnetworking/sys/mbuf.h,
libnetworking/sys/mount.h, libnetworking/sys/protosw.h,
libnetworking/sys/queue.h, libnetworking/sys/rtprio.h,
libnetworking/sys/select.h, libnetworking/sys/signalvar.h,
libnetworking/sys/socket.h, libnetworking/sys/socketvar.h,
libnetworking/sys/sysctl.h, libnetworking/sys/syslog.h,
libnetworking/sys/ucred.h, libnetworking/sys/uio.h,
libnetworking/vm/vm.h, libnetworking/vm/vm_extern.h,
libnetworking/vm/vm_param.h: Use -D_KERNEL instead of -DKERNEL for
greater FreeBSD compliance.
* libnetworking/Makefile.am: Add -D_KERNEL to CPPFLAGS.
* libnetworking/net/bpf.h: Partial update from FreeBSD.
* libnetworking/sys/sysctl.h: Partial update from FreeBSD.
* libnetworking/kern/kern_sysctl.c: Partial update from FreeBSD.
* libfs/src/imfs/imfs_debug.c, libfs/src/imfs/memfile.c:
Use fprintf(stdout,...) instead of printf.
* libblock/src/ide_part_table.c: Use fprintf(stdout,...) instead of
printf.
* libmisc/capture/capture-cli.c, libmisc/cpuuse/cpuuse.c,
libmisc/dumpbuf/dumpbuf.c, libmisc/fsmount/fsmount.c,
libmisc/monitor/mon-command.c, libmisc/monitor/mon-config.c,
libmisc/monitor/mon-dname.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-extension.c, libmisc/monitor/mon-itask.c,
libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-mpci.c,
libmisc/monitor/mon-object.c, libmisc/monitor/mon-prmisc.c,
libmisc/monitor/mon-queue.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/mon-task.c, libmisc/rtmonuse/rtmonuse.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c, libmisc/shell/shell.h,
libmisc/stackchk/check.c, libmisc/untar/untar.c: Use
* sapi/include/rtems/sptables.h: Remove _RTEMS_version.
* rtems/score/i386.h: Rename i386_swap_U* to i386_swap_u* (API
consistency with other ports).
* libcsupport/Makefile.am: Install include_sys_HEADERS for NEWLIB
only. Merge sys/cdefs.h into general include_sys_HEADERS.
PR 605/bsps
* cpu.c: Remove further c++ style comments having been missed in
previous patch. Remove printf's entirely.
* rtems/include/rtems/rtems/types.h: Include <rtems/stdint.h>
instead of <stdint.h>.
Conditionally typedef rtems*signed64 types.
* score/include/rtems/system.h: Include <rtems/stdint.h> instead of
<stdint.h>.
* configure.ac: Rework stdint.h/inttypes.h support.
Add RTEMS_USES_STDINT_H. Add RTEMS_USES_INTTYPES_H.
Remove NEED_STDINT_H. Remove NEED_INTTYPES_H.
Remove termios-flag detection.
* libcsupport/Makefile.am: Install include/stdint.h and
include/inttypes.h for NEWLIB only.
* libcsupport/include/stdint.h: Rework; Now newlib specific.
* libcsupport/src/termios.c: Make newlib specific.
* include/rtems/stdint.h: Rework; Now wrapper to <stdint.h>.
* asm.h: New (stub file. For consistency with other ports, only).
* Makefile.am: Add asm.h.
* asm.h: Include rtems/score/powerpc.h instead of
rtems/score/ppc.h.
* rtems/score/powerpc.h: New (Copied and renamed from rtems/score/ppc.h)
for consistency with other ports.
* rtems/score/ppc.h: Deprecation wrapper to rtems/score/powerpc.h.
* rtems/score/cpu.h: Include rtems/score/powerpc.h instead of
rtems/score/ppc.h.
* asm.h, rtems/new-exceptions/cpu.h, rtems/score/ppc.h: addition of
MPC555 support as part of the addition of the SS555 BSP.
* rtems/score/cpu.h: Remove defining _POSIX_C_SOURCE for solaris.
* acinclude.m4 (RTEMS_CPUOPT): Use AC_DEFINE_UNQUOTED.
* backward/motorola/mc68681.h, backward/motorola/mc68230.h,
backward/zilog/z8536.h, backward/zilog/z8036.h,
backward/zilog/z8030.h: New.
* Makefile.am: Reflect having added new files above.
