* | Move various compression libraries into single subdirectory | Joel Sherrill | 2023-06-06 | 1 | -93/+0 |
| | | | | | | This improves the organization of the cpukit. Closes #4912. | ||||
* | zlib: Update from 1.2.5 to 1.2.13 | Sebastian Huber | 2023-05-09 | 1 | -32/+68 |
| | | | | | | | | | | | | The updated files were extracted from: https://www.zlib.net/zlib-1.2.13.tar.xz The archive had an SHA-256 hash value of: d14c38e313afc35a9a8760dadf26042f51ea0f5d154b0630a31da0540107fb98 Close #4902. | ||||
* | 2010-03-22 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-03-18 | 1 | -8/+6 |
| | | | | | | | | | | * ChangeLog.zlib, FAQ, Makefile.am, README, adler32.c, compress.c, crc32.c, deflate.c, deflate.h, infback.c, inffast.c, inflate.c, inflate.h, inftrees.c, inftrees.h, trees.c, uncompr.c, zconf.h, zlib.3, zlib.h, zutil.c, zutil.h: Update to zlib 1.2.4. * gzclose.c, gzguts.h, gzlib.c, gzread.c, gzwrite.c, doc/algorithm.txt: New files. * algorithm.txt, gzio.c: Removed. | ||||
* | Stop using old-style function definitions. | Ralf Corsepius | 2008-09-02 | 1 | -5/+5 |
* | Upgrade to zlib-1.2.3. | Ralf Corsepius | 2008-09-01 | 1 | -1/+1 |
* | Reformat CVS Ids | Ralf Corsepius | 2005-10-28 | 1 | -1/+1 |
* | Import of zlib-1.2.2.2.tar.gz | Ralf Corsepius | 2005-10-28 | 1 | -0/+61 |
