* | Remove. | Ralf Corsepius | 2010-06-09 | 35 | -8056/+0 |
* | Regenerate. | Ralf Corsepius | 2010-04-29 | 1 | -1/+1 |
* | Use SLIBHTTPD. | Ralf Corsepius | 2010-04-29 | 1 | -1/+3 |
* | 2010-04-13 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-13 | 1 | -1/+1 |
| | | | | | * shttpd/io_dir.c: Cast consts to size_t (Avoid overflows on implicit const casts on 16bit targets). | ||||
* | #include <unistd.h>. | Ralf Corsepius | 2010-04-03 | 6 | -0/+10 |
* | Add HAVE_STRINGS_H for better POSIX compliance. | Ralf Corsepius | 2010-03-26 | 4 | -0/+16 |
* | 2009-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-12-02 | 1 | -1/+1 |
| | | | | * shttpd/def.h: Use __m32c__ for m32c. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-12-02 | 9 | -22/+22 |
* | 2009-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-12-02 | 1 | -0/+20 |
| | | | | | * shttpd/def.h: Shrink default URI_MAX to 32767. Add special cases for sizeof(size_t) < 2. | ||||
* | 2008-08-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-18 | 1 | -0/+1 |
| | | | | | | | | * libcsupport/include/rtems/libcsupport.h, libcsupport/src/scandir.c, libmisc/cpuuse/cpuusagereset.c, libmisc/monitor/mon-monitor.c, libmisc/serdbg/serdbg.c, libmisc/serdbg/serdbg.h, libnetworking/netinet/in_cksum_powerpc.h, shttpd/compat_rtems.h: Fix warnings. | ||||
* | Replace C++-comments with C-comments. | Ralf Corsepius | 2008-07-31 | 1 | -6/+8 |
* | 2008-03-25 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2008-03-25 | 1 | -1/+3 |
| | | | | | * shttpd/log.c: Activate SPLIT_SNPRINTF for gcc <= 4.2.3 and coldfire. | ||||
* | 2007-09-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-09-06 | 1 | -35/+32 |
| | | | | * shttpd/compat_rtems.c: Style clean up. | ||||
* | changes | Ralf Corsepius | 2007-07-30 | 1 | -6/+4 |
* | 2007-07-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-07-30 | 1 | -0/+30 |
| | | | | | | * shttpd/log.c: Add preliminary version of SPLIT_SNPRINTF to work-around bug m68k/coldfire -fomit-frame-pointer bug http://gcc.gnu.org/bugzilla/show_bug.cgi?id=32307. | ||||
* | Don't build most of my_* wrappers for rtems. | Ralf Corsepius | 2007-07-24 | 1 | -0/+9 |
* | Don't build my_stat for rtems. | Ralf Corsepius | 2007-07-24 | 1 | -2/+2 |
* | Prefix all non-public symbols with _shttp_. | Ralf Corsepius | 2007-07-24 | 1 | -0/+37 |
* | 2007-07-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-07-12 | 2 | -5/+9 |
| | | | | | * shttpd/compat_rtems.c, shttpd/compat_rtems.h: Add port to listen on to shttpd initialization. | ||||
* | 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-12 | 2 | -0/+12 |
| | | | | | * shttpd/defs.h: Eliminate my_strncasecmp. * shttpd/string.c: Eliminate my_strncasecmp. | ||||
* | Eliminate my_strlcpy. | Ralf Corsepius | 2007-06-12 | 2 | -0/+9 |
* | Eliminate my_strdup, my_strndup. | Ralf Corsepius | 2007-06-12 | 2 | -0/+15 |
* | 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-12 | 1 | -1/+1 |
| | | | | | * shttpd/Makefile.am: Add -DHAVE_MD5 to use md5 routines from libmd.a. | ||||
* | Remove. | Ralf Corsepius | 2007-06-11 | 2 | -1/+0 |
* | Regenerate. | Ralf Corsepius | 2007-06-11 | 1 | -1/+1 |
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 1 | -1/+1 |
| | | | | * shttpd/Makefile.am: Conditionally build on LIBNETWORKING. | ||||
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 1 | -0/+5 |
| | | | | | * shttpd/compat_rtems.h: Include <arpa/inet.h>. Add config.h support. | ||||
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 1 | -0/+1 |
| | | | | * shttpd/compat_rtems.h: Define closesocket. | ||||
* | New. | Ralf Corsepius | 2007-06-11 | 1 | -0/+2 |
| | | | | * shttpd/compat_rtems.h: Add IS_DIRSEP_CHAR. | ||||
* | Use size_t for stack sizes. | Ralf Corsepius | 2007-06-11 | 2 | -2/+2 |
* | New. | Ralf Corsepius | 2007-06-11 | 1 | -0/+39 |
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 1 | -0/+31 |
| | | | | * shttpd/Makefile.am: New. | ||||
* | Remove (Renamed to Makefile.shttpd) | Ralf Corsepius | 2007-06-11 | 1 | -50/+0 |
* | Rename shttpd's Makefile | Ralf Corsepius | 2007-06-11 | 1 | -0/+50 |
* | Import from shttpd-1.37. | Ralf Corsepius | 2007-06-11 | 34 | -0/+7814 |
