path: root/cpukit/score (follow)
* score: More robust _SMP_Multicast_action()Sebastian Huber2019-04-121-2/+12
| | | | | | If the caller already disabled interrupts, then do not disable thread dispatching. Calling _SMP_Multicast_action() with interrupts disabled is a questionable use case.
* score: Remove _SMP_Before_multitasking_action()Sebastian Huber2019-04-122-96/+0
| | | | Use _SMP_Multicast_action() instead.
* score: Improve _SMP_Multicast_action()Sebastian Huber2019-04-122-7/+22
| | | | Let it work during system initialization.
* score: Rework SMP multicast actionSebastian Huber2019-04-122-76/+174
| | | | | Use a FIFO list of jobs per processor to carry out the SMP multicast action. Use a done indicator per job to reduce the bus traffic a bit.
* score: Use processor mask in _SMP_Multicast_actionSebastian Huber2019-04-121-17/+7
| | | | Processor_mask is the internal data type to deal with processor sets.
* score: Use an ISR lock for Per_CPU_Control::LockSebastian Huber2019-04-125-22/+23
| | | | | | The use of a hand crafted lock for Per_CPU_Control::Lock was necessary at some point in the SMP support development, but it is no longer justified.
* score: Add _ISR_lock_Set_name()Sebastian Huber2019-04-121-2/+3
| | | | | Add _ISR_lock_Set_name() to optimize the initialization of zero-initialized locks.
* score: Rename _SMP_Get_processor_count()Sebastian Huber2019-04-115-29/+39
| | | | | | | Rename _SMP_Get_processor_count() in _SMP_Get_processor_maximum() to be in line with the API level rtems_scheduler_get_processor_maximum(). Update #3732.
* score: Rename _SMP_Processor_countSebastian Huber2019-04-111-2/+2
| | | | | | | Rename _SMP_Processor_count in _SMP_Processor_maximum to be in line with the API level rtems_scheduler_get_processor_maximum(). Update #3732.
* Remove superfluous run-time checkSebastian Huber2019-04-091-4/+1
| | | | | The _Objects_Information_table[ the_api ] is never NULL for a valid API index.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-04157-157/+157
| | | | Update #3706
* doxygen: Added Management to Example CPU ArchitectureAndreas Dachsberger2019-04-041-0/+8
| | | | Update #3706.
* doxygen: score: Put ARM Co-Processor 15 group in ARMAndreas Dachsberger2019-04-021-3/+3
| | | | Update #3706.
* doxygen: score: Add x86-64 CPU architecture groupAndreas Dachsberger2019-04-022-0/+24
| | | | Update #3706.
* doxygen: score: Add V850 CPU architecture groupAndreas Dachsberger2019-04-023-18/+54
| | | | Update #3706.
* doxygen: score: Add SPARC64 CPU architecture groupAndreas Dachsberger2019-04-022-0/+22
| | | | Update #3706.
* doxygen: score: Add SPARC CPU architecture groupAndreas Dachsberger2019-04-023-2/+26
| | | | Update #3706.
* doxygen: score: Add SuperH CPU architecture groupAndreas Dachsberger2019-04-022-0/+20
| | | | Update #3706.
* doxygen: score: Add RISC-V CPU architecture groupAndreas Dachsberger2019-04-024-1/+26
| | | | Update #3706.
* doxygen: score: Add powerpc CPU architecture groupAndreas Dachsberger2019-04-025-2/+32
| | | | Update #3706.
* doxygen: score: Add or1k CPU architecture groupAndreas Dachsberger2019-04-024-1/+27
| | | | Update #3706.
* doxygen: score: Add nios2 CPU architecture groupAndreas Dachsberger2019-04-013-0/+26
| | | | Update #3706.
* doxygen: score: Add Moxie CPU architecture groupAndreas Dachsberger2019-04-013-0/+26
| | | | Update #3706.
* doxygen: score: Add m68k CPU architecture groupAndreas Dachsberger2019-04-019-10/+47
| | | | Update #3706.
* doxygen: score: Change no_cpu architecture groupAndreas Dachsberger2019-04-012-36/+49
| | | | | | Groups CPUContext and CPUInterrupt are now defined with a unique name for this architecture group. Update #3706.
* doxygen: score: Add lm32 CPU architecture groupAndreas Dachsberger2019-04-013-14/+53
| | | | Update #3706.
* doxygen: score: Add i386 CPU architecture groupAndreas Dachsberger2019-04-018-2/+57
| | | | Update #3706.
* doxygen: score: Add Epiphany CPU architecture groupAndreas Dachsberger2019-04-014-2/+20
| | | | Update #3706.
* doxygen: score: Add Blackfin CPU architecture groupAndreas Dachsberger2019-04-012-16/+43
| | | | Update #3706.
* score: Add ARM CPU architecture groupSebastian Huber2019-03-2610-52/+32
| | | | Update #3706.
* score: Add example CPU architecture groupSebastian Huber2019-03-262-2/+14
| | | | Update #3706.
* score: Rename ScoreCPU Doxygen groupSebastian Huber2019-03-2614-16/+15
| | | | Update #3706.
* Remove superfluous <rtems/system.h> includesSebastian Huber2019-03-1443-43/+1
* sparc64: Do not include <rtems/asm.h> in C sourceSebastian Huber2019-03-141-1/+0
* coremsgseize.c: Fix spelling errorJoel Sherrill2019-03-121-1/+1
* cpukit/arm: Correct register definitionJonathan Brandmeyer2019-03-081-2/+2
| | | | | | | | | | | | | | The register definition for the CP15 PMCR (performance monitor control register) has the bits for X (export enable) and D (clock divider enable) backwards. Correct them according to ARMv7-A/R Architecture Reference Manual, Rev C, Section B4.1.117. Consequences: On an implementation that starts off with D set at reset, the clock divider will not be disabled by using RTEMS' definition of the D bit. Tested by using the counter on Xilinx Zynq 7020 to measure some atomic accesses and cache flushing operations.
* score: Fix _Scheduler_EDF_Cancel_job()Sebastian Huber2019-03-011-2/+4
| | | | Remove the priority node only in case it is active.
* Remove explicit file names from @fileSebastian Huber2019-02-2825-25/+25
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* bsps/arm: Fix system register for virtual timerKinsey Moore2019-02-221-1/+1
| | | | | | | | | The system register in use for retrieval of the virtual timer value was mistakenly copied from the physical timer value retrieval function. Virtual timer value retrieval should use the same system register as the virtual timer value setter. Close #3699.
* score: Avoid some deadlocks in _Once()Sebastian Huber2019-02-181-43/+74
| | | | | | | | Recursive usage of the same pthread_once_t results now in a deadlock. Previously, an error of EINVAL was returned. This usage scenario is invalid according to the POSIX pthread_once() specification. Close #3334.
* libdl: Fix the support for constructors and desctructors.Chris Johns2019-02-091-20/+52
| | | | | | | - Fix the handling of pending objects. - Add a constructor flags in objects to track then being called. Closes #2921
* score: Fix plain priority thread queues (SMP)Sebastian Huber2019-02-071-0/+8
| | | | We must add/remove the priority queue to the FIFO of priority queues.
* riscv: Fix misaligned access in context validateSebastian Huber2019-02-021-1/+1
* m68k: Avoid _Addresses_Add_offset()Sebastian Huber2019-01-291-4/+2
| | | | | This prevents a cyclic dependency between <rtems/score/cpu.h> and <rtems/score/address.h>.
* riscv: add griscv bspJiri Gaisler2019-01-221-4/+1
| | | | Update #3678.
* grlib: use cpu-independent routines for uncached accessJiri Gaisler2019-01-223-0/+83
| | | | Update #3678.
* score: Avoid internal API and use ISR lockSebastian Huber2019-01-181-9/+9
* m68k/include/rtems/score/cpu.h: Add include of address.hJoel Sherrill2019-01-141-0/+2
* riscv: Enable robust thread dispatchSebastian Huber2019-01-091-0/+3
| | | | | | | It must be enabled, since the context switch code does not save/restore the interrupt status. Update #3433.
* Adjust interrupt mode tests for some CPU portsSebastian Huber2019-01-092-2/+4
| | | | | | | In case the robust thread dispatch is enabled by the CPU port, then the interrupt level must not be changed through the task mode. Update #3000.
