* rtems/score/avr.h: Add avr25, avr31, avr35, avr51 to
CPU_NAME cascade.
* rtems/score/cpu.h: Add missing prototypes.h.
* rtems/score/types.h: Include stdbool.h.
Use bool as base-type for boolean.
* libmisc/dummy/dummy.c: Add missing initializers.
* score/src/threadinitialize.c: Change type of loop counter.
* rtems/score/cpu.h: Correct prototype of _CPU_Thread_dispatch_pointer.
* cpu.c: Fix prototypes.
* rtems/score/cpu.h: Use memcpy() initialize FP structure and avoid
many casts and potential warnings.
* rtems/score/cpu.h: Fix type when initializing FP context.
* cpu.c, rtems/score/cpu.h: Add extern for bfffo table and rename it to
indicate that it is specific to this architecture.
* score/inline/rtems/score/threadmp.inl: Add include of
rtems/score/mpci.h and remove extern.
* rtems/score/cpu.h: Add missing prototype.
* cpu.c, rtems/score/cpu.h: Add void.
* itron/include/rtems/itron/task.h, itron/src/def_cyc.c,
itron/src/task.c, libcsupport/src/newlibc_exit.c,
libcsupport/src/sync.c, libfs/src/imfs/imfs_fchmod.c,
posix/include/rtems/posix/pthread.h, posix/src/pthread.c,
posix/src/sysconf.c, rtems/include/rtems/rtems/tasks.h,
rtems/src/tasks.c, score/include/rtems/score/stack.h,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/thread.inl, score/src/threadhandler.c: Fix
various nested-externs warnings.
* rtems/score/cpu.h, rtems/score/i386.h: Add missing prototypes.
* ChangeLog: Add correct entry.
* rtems/include/rtems/rtems/ratemon.h,
rtems/include/rtems/rtems/status.h,
score/include/rtems/score/object.h: Removed extraneous commas.
* rtems/powerpc/registers.h: Removed obsolete defines MSR_, MSR_KERNEL
and MSR_USER. Added missing prototypes.
* libmisc/monitor/monitor.h, rtems/include/rtems/rtems/tasks.h,
score/include/rtems/score/thread.h, score/src/threadreset.c,
score/src/threadrestart.c, score/src/threadstart.c: New type
Thread_Entry_numeric_type for numeric arguments in thread entry
functions with at least one numeric argument.
* score/include/rtems/score/sysstate.h,
score/inline/rtems/score/sysstate.inl, score/src/thread.c: Make
_System_state_Is_multiprocessing unused when multiprocessing is not
enabled. Saves one more variable from single processor configuration.
* rtems/include/rtems/rtems/sem.h, rtems/src/semobtain.c:
Changed option set type to rtems_option.
* score/src/objectgetinfo.c: Check return value of
_Objects_API_maximum_class().
* libmisc/monitor/mon-mpci.c, libmisc/monitor/monitor.h,
rtems/include/rtems/rtems/message.h, rtems/src/msgmp.c,
rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqcreate.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c,
rtems/src/msgqurgent.c, score/include/rtems/score/coremsg.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/thread.h,
score/inline/rtems/score/coremsg.inl, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgseize.c,
score/src/coremsgsubmit.c:
Removed parameters of _Message_queue_Allocate(). Changed option set
type to rtems_option. Changed type of maximum message and packet size
to size_t. Changed the input buffer type for message send functions to
"const void *". Changed the pointer to the second return argument in
the thread wait information to a union. This union can contain a
pointer to an immutable or a mutable object. This is somewhat fragile.
An alternative would be to add a third pointer for immutable objects,
but this would increase the structure size.
* rtems/new-exceptions/cpu.h: Changed define
CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER to UINT32_MAX to avoid comparison
between signed and unsigned.
PR 1212/cpukit
* rtems/src/taskmode.c, score/src/threadtickletimeslice.c: Time slicing
will not happen if the task mode is changed from a non-timeslicing
mode to timeslicing mode if it is done by the executing thread (e.g.
in its task body). This change includes sp44 to demonstrate the
problem and verify the correction.
PR 1294/bsps
* rtems/score/cpu.h, rtems/score/sparc.h: Correct prototype and usage
of sparc_disable_interrupts.
* rtems/score/cpu.h: Spacing.
PR 1265/cpukit
* score/include/rtems/score/object.h,
score/src/objectallocatebyindex.c: Rename index argument to avoid
warning when rtems.h and string.h are included at the same time by
user code.
* cpu.c, rtems/score/cpu.h: Correct prototype of Idle threads.
* rtems/score/cpu.h: Correct prototype of Idle threads.
* libblock/Makefile.am: Removed src/show_bdbuf.c.
* libblock/src/show_bdbuf.c: Removed.
* libblock/include/rtems/bdbuf.h, cpukit/libblock/src/bdbuf.c:
Rewritten the bdbuf code. Remove pre-emption disable, score
access, fixed many bugs and increased performance.
* libblock/include/rtems/blkdev.h: Added
RTEMS_BLKDEV_CAPABILITIES block device request. Cleaned up
comments. Added block and user fields to the sg buffer
request. Move to rtems_* namespace.
* libblock/include/rtems/diskdevs.h,
cpukit/libblock/src/diskdevs.c: Move to rtems_* namespace. Add a
capabilities field for drivers. Change rtems_disk_lookup to
rtems_disk_obtain to match the release call. You do not lookup and
release a disk, you obtain and release a disk.
* libblock/include/rtems/ide_part_table.h,
libblock/include/rtems/ramdisk.h, libblock/src/ide_part_table.c:
* libblock/include/rtems/nvdisk.h: Formatting change.
* libblock/src/blkdev.c: Move to rtems_* namespace. Change
rtems_disk_lookup to rtems_disk_obtain
* libblock/src/flashdisk.c: Move to rtems_* namespace. Use the new
support for the block number in the scatter/grather request
struct. This allows non-continuous buffer requests for those
drivers that can support increasing performance.
* libblock/src/nvdisk.c: Move to rtems_* namespace. Removed
warnings. Added better error checking. Fixed some comments.
* libblock/src/ramdisk.c: Move to rtems_* namespace. Added some
trace functions to help debugging upper layers. Use the new
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Use new chains
API. Removed temporary hack and changed
set_errno_and_return_minus_one to
rtems_set_errno_and_return_minus_one. Move fat_buf_access from
header and stopped it being inlined. Updated to libblock changes.
* libfs/src/dosfs/fat_fat_operations.c,
libfs/src/dosfs/fat_file.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Use
new chains API. Removed temporary hack and changed
rtems_set_errno_and_return_minus_one. Updated to libblock changes.
* libmisc/Makefile.am: Add new ls and rm command files.
* libmisc/shell/cmp-ls.c, libmisc/shell/extern-ls.h,
libmisc/shell/filemode.c, libmisc/shell/print-ls.c,
libmisc/shell/pwcache.c, libmisc/shell/utils-ls.c,
libmisc/shell/vis.c, shell/vis.h: New.
* libmisc/shell/extern-cp.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c: Fixed the usage call bug.
* libmisc/shell/main_blksync.c: Updated to the new block IO ioctl
command.
* libmisc/shell/main_ls.c, libmisc/shell/main_rm.c: Updated to BSD
commands with more features.
* score/src/coremutex.c: Fix the strick order mutex code.
* libmisc/shell/shell.c: Change shell tasks mode to be timeslice
and no ASR.
* sapi/include/confdefs.h: Change ata_driver_task_priority to
rtems_ata_driver_task_priority. Add the new BD buf cache
parameters with defaults.
* score/src/interr.c: Do not return if the CPU halt call returns.
* sapi/include/confdefs.h, score/src/threadcreateidle.c: Idle thread
body is now completely configured via the Configuration table.
PR 1291/cpukit
* itron/inline/rtems/itron/semaphore.inl, itron/src/twai_sem.c,
posix/include/mqueue.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/time.h, posix/src/condtimedwait.c,
posix/src/mqueuereceive.c, posix/src/mqueuerecvsupp.c,
posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c,
posix/src/mutextimedlock.c, posix/src/mutextranslatereturncode.c,
posix/src/posixtimespecabsolutetimeout.c,
posix/src/semaphoretranslatereturncode.c,
posix/src/semaphorewaitsupp.c, posix/src/semtimedwait.c,
posix/src/semtrywait.c, posix/src/semwait.c,
posix/src/sigtimedwait.c, posix/src/timersettime.c,
posix/src/ualarm.c, rtems/src/semobtain.c,
rtems/src/semtranslatereturncode.c,
score/include/rtems/score/coresem.h, score/src/coresemseize.c: This
patch addresses issues on implementation of the timeout on the
following POSIX services. Some of these services incorrectly took a
timeout as a relative time. Others would compute a 0 delta to timeout
if the absolute time and the current time were equal and thus
incorrectly block the caller forever. The root of the confusion is
that POSIX specifies that if the timeout is incorrect (e.g. in the
past, is now, or is numerically invalid), that it does not matter if
the call would succeed without blocking. This is in contrast to RTEMS
programming style where all errors are checked before any critical
sections are entered. This fix implemented a more uniform way of
handling POSIX absolute time timeouts.
+ pthread_cond_timedwait - could block forever
+ mq_timedreceive - used relative not absolute time
+ mq_timedsend - used relative not absolute time
+ pthread_mutex_timedlock - used relative not absolute time
+ pthread_rwlock_timedrdlock- used relative not absolute time
+ pthread_rwlock_timedwrlock- used relative not absolute time
+ sem_timedwait - could block forever
fixed some minors in mpc83xx support
added file for mpc55xx watchdog support
* score/cpu/powerpc/rtems/new-exceptions/cpu.h:
use ppc_interrupt_get_disable_mask() to determine
which bits to set/clear from _CPU_ISR_Set_level().
* score/cpu/powerpc/rtems/powerpc/registers.h:
added ppc_interrupt_get_disable_mask() inline function.
* cpukit/score/cpu/powerpc/rtems/new-exceptions/cpu.h,
cpukit/score/cpu/powerpc/rtems/score/cpu.h,
cpukit/score/cpu/powerpc/rtems/score/powerpc.h:
Removed all macro definitions which depended on
the compiler defining a PPC CPU-model dependent
symbol.
Macros which were not used by cpukit have been
moved to libcpu/powerpc/rtems/powerpc/powerpc.h.
