Close #2720.
Close #2719.
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
Get rid of the mp_id parameter used for some thread queue methods. Use
THREAD_QUEUE_QUEUE_TO_OBJECT() instead.
We must call the MP callout for proxies if we unblock them after a
thread queue extraction. This was missing in
_Thread_queue_Flush_critical(). Move thread remove timer and unblock
code to new function _Thread_Remove_timer_and_unblock().
of this patch set.
Close #2718.
Delete unused parameter.
Uniformly use *_Get() to get an object by identifier with a lock
context.
Rename _Objects_Get_local() into _Objects_Get(). Confusions with the
previous _Objects_Get() function are avoided since the Objects_Locations
parameter is gone.
Delete now unused Objects_Locations.
Use _RBTree_Insert_inline() for priority thread queues.
Update #2556.
The priority values are only valid within a scheduler instance. Thus,
the maximum priority value must be defined per scheduler instance. The
first scheduler instance defines PRIORITY_MAXIMUM. This implies that
RTEMS_MAXIMUM_PRIORITY and POSIX_SCHEDULER_MAXIMUM_PRIORITY are only
valid for threads of the first scheduler instance. Further
API/implementation changes are necessary to fix this.
Update #2556.
Update #2555.
This is a preparation to remove the Giant lock.
Update #2555.
Rename _ISR_Disable() into _ISR_Local_disable(). Rename _ISR_Enable()
into _ISR_Local_enable(). Remove _Debug_Is_owner_of_giant().
Update #2555.
Rename _ISR_Disable_without_giant() into _ISR_Local_disable(). Rename
_ISR_Enable_without_giant() into _ISR_Local_enable().
Update #2555.
Avoid _Thread_Dispatch_increment_disable_level() and
_Thread_Dispatch_decrement_disable_level() and thus the Giant
lock.
Update #2555.
Avoid Giant lock for _Objects_Extend_information().
Update #2280.
Update #2555.
Update #2555.
Update #2555.
Add Thread_Life_state::THREAD_LIFE_CHANGE_DEFERRED and rework the POSIX
thread cancellation to use the thread life states.
Update #2555.
Update #2626.
Update #2555.
Rework pthread_join() to use _Thread_Join().
Close #2402.
Update #2555.
Update #2626.
Close #2714.
Use _Thread_Change_life_locked() to avoid duplicated code. Avoid Giant
lock in _Thread_Life_action_handler().
Update #2555.
Update #2626.
Rework _Thread_Cancel() to use _Thread_Change_life_locked().
Update #2555.
Update #2626.
Rework _Thread_Restart_other() to use _Thread_Change_life_locked().
Cope with concurrent change requests by means of a pending request
counter.
Update #2555.
Update #2626.
Split _Thread_Restart() into _Thread_Restart_self() and
_Thread_Restart_other(). Move content of existing
_Thread_Restart_self() into new _Thread_Restart_self(). Avoid Giant
lock for thread restart. _Thread_Restart_self() is a no-return function
and used by _Thread_Global_construction().
Update #2555.
Update #2626.
Update #2555.
Update #2626.
This makes it possible to do thread state and thread life changes
together under protection of the thread state lock.
Update #2555.
Update #2626.
Update #2555.
Update #2626.
Split _Thread_Close() into _Thread_Join() and _Thread_Cancel() to
prepare for a re-use in pthread_join() and pthread_cancel().
Update #2555.
Update #2626.
Rework _Thread_Exit() to use _Thread_Change_life_locked().
Update #2555.
Update #2626.
Update #2555.
Update #2626.
Add _Thread_Change_life_locked() as a general function to alter the
thread life state. Use it to implement _Thread_Set_life_protection() as
a first step.
Update #2555.
Update #2626.
Update #2555.
Update #2626.
Disable thread dispatching is enough to prevent deletion of the
executing thread. There is no need for an additional life protection.
Update #2555.
Update #2626.
The goal is to make _Thread_Exit() a no-return function in follow up
patches.
Update #2555.
Update #2626.
This makes it easier to add more states in the future.
Update #2555.
Update #2626.
Added only for evaluation purposes. We have to compare the performance
against the ticket lock on the interesting platforms via
smptests/smplock01.
The following GCC shortcoming affects the MCS lock:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=66867
Update #2555.
