* configure.ac, libmisc/cpuuse/README, libmisc/stackchk/README,
librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am,
score/include/rtems/score/mppkt.h: i960 obsoleted and all references
removed.
* rtems/score/cpu.h: i960 obsoleted and all references removed.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h: i960
* score/cpu/i960/.cvsignore, score/cpu/i960/ChangeLog,
score/cpu/i960/Makefile.am, score/cpu/i960/asm.h,
score/cpu/i960/cpu.c, score/cpu/i960/cpu_asm.S,
score/cpu/i960/rtems/score/cpu.h, score/cpu/i960/rtems/score/i960.h,
score/cpu/i960/rtems/score/types.h: Removed.
* configure.ac: Add score/cpu/avr/Makefile.am.
* score/cpu/Makefile.am: Add avr.
PR 671/bsps
* rtems/score/cpu.h: Fixed bug in _CPU_ISR_Set_level, where input param
was always ignored.
PR 609/rtems
* score/src/threaddispatch.c: Close race condition between
_Thread_Dispatch and _Thread_Tickle_timeslice.
PR 654/rtems
* score/src/threadinitialize.c: Initialize the per thread watchdog
timer. When the thread control block is reused, we cannot depend on
it being zeroed.
* cpu_asm.S: Remove use of C++ style comments and make this compile
again.
* rtems/score/m68k.h: Add include of <stdint.h> for uint32_t used by
endian swapping routines.
PR 661/rtems
* score/src/objectmp.c: Fix invalid dereference.
PR 660/rtems
* score/cpu/m68k/rtems/score/m68k.h, score/cpu/mips/cpu_asm.S,
score/src/threadinitialize.c, score/src/threadstackallocate.c: Check
for overflow when allocating stack.
PR 659/rtems
* score/src/heapsizeofuserarea.c: Check that address specified is in
the heap.
PR 650/rtems
* score/src/coremsg.c: Check for mathemathical overflow when calculating
amount of memory to allocate for message buffers.
PR 618/rtems
* rtems/include/rtems/rtems/status.h, rtems/src/clockget.c,
rtems/src/clockset.c, rtems/src/dpmemcreate.c,
rtems/src/dpmemexternal2internal.c,
rtems/src/dpmeminternal2external.c, rtems/src/eventmp.c,
rtems/src/eventreceive.c, rtems/src/eventsend.c,
rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c,
rtems/src/msgqreceive.c, rtems/src/msgqsubmit.c,
rtems/src/partcreate.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/ratemoncancel.c,
rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, rtems/src/regioncreate.c,
rtems/src/regiondelete.c, rtems/src/regionextend.c,
rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c,
rtems/src/regionreturnsegment.c, rtems/src/semcreate.c,
rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c,
rtems/src/taskcreate.c, rtems/src/taskgetnote.c,
rtems/src/taskmode.c, rtems/src/taskrestart.c,
rtems/src/taskresume.c, rtems/src/tasksetnote.c,
rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c,
rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c,
rtems/src/taskwakewhen.c, rtems/src/timercreate.c,
rtems/src/timerfirewhen.c, rtems/src/timerserverfireafter.c,
rtems/src/timerserverfirewhen.c, score/include/rtems/score/object.h,
score/src/coretodvalidate.c, score/src/objectnametoid.c: Add NULL
checks.
* rtems/score/i386.h: Rename i386_swap_U* to i386_swap_u* (API
consistency with other ports).
PR 605/bsps
* cpu.c: Remove further c++ style comments having been missed in
previous patch. Remove printf's entirely.
* rtems/include/rtems/rtems/types.h: Include <rtems/stdint.h>
instead of <stdint.h>.
Conditionally typedef rtems*signed64 types.
* score/include/rtems/system.h: Include <rtems/stdint.h> instead of
<stdint.h>.
* asm.h: New (stub file. For consistency with other ports, only).
* Makefile.am: Add asm.h.
* asm.h: Include rtems/score/powerpc.h instead of
rtems/score/ppc.h.
* rtems/score/powerpc.h: New (Copied and renamed from rtems/score/ppc.h)
for consistency with other ports.
* rtems/score/ppc.h: Deprecation wrapper to rtems/score/powerpc.h.
* rtems/score/cpu.h: Include rtems/score/powerpc.h instead of
rtems/score/ppc.h.
* asm.h, rtems/new-exceptions/cpu.h, rtems/score/ppc.h: addition of
MPC555 support as part of the addition of the SS555 BSP.
* rtems/score/cpu.h: Remove defining _POSIX_C_SOURCE for solaris.
PR 605/bsps
* cpu.c: Do not use C++ style comments.
* rtems/score/cpu.h: Fix typo.
* cpu_asm.S: Convert asm comments to C-comments to prevent gcc-3.4.0pre
from choking on them.
* Makefile.am: Remove LIBC_DEFINES (Unsupported).
* score/cpu/Makefile.am: Add unix to DIST_SUBDIRS.
* aclocal/rtems-cpu-subdirs.m4: Remove (Unused).
* configure.ac: Remove RTEMS_CPU_SUBDIRS([score/cpu]).
Add RTEMS_CHECK_SYSV_UNIX.
Add score/cpu/*/Makefile.
* score/cpu/Makefile.am: Add DIST_SUBDIRS.
* configure.ac: Remove (Merged into $(top_srcdir)/configure.ac).
* Makefile.am: Don't include multilib.am.
Reflect merging configure.ac into $(top_srcdir)/configure.ac.
* configure.ac: Remove (Merged into$(top_srcdir)/configure.ac).
* rtems/score/cpu.h: Remove unixsize.h.
* Makefile.am: Remove unixsize.h.
PR 598/bsps
* cpu_asm.S, rtems/score/cpu.h: Add save of floating point
status/control register on context switches. Missing this register
was causing intermittent floating point errors.
* Makefile.am: Install m68302.h m68360.h qsm.h sim.h
to $(includedir)/rtems/m68k.
* Makefile.am: Install iregdefs.h and idtcpu.h to
$(includedir)/rtems/mips.
* cpu_asm.S: Include <rtems/mips/iregdef.h> instead of <iregdef.h>.
* rtems/score/mips.h, cpu_asm.S: Include <rtems/mips/idtcpu.h>
instead of <idtcpu.h>.
* Makefile.am: Install c4xio.h to $(includedir)/rtems/c4x.
