Created futimens.c and utimensat.c to add support for the POSIX
methods futimens() and utimensat().
utime() and utimes() are considered obsolote by POSIX, but RTEMS
will continue to support them.
Closes #4396
Currently, the AArch64 BSPs have a hard time running on real hardware
without building the toolchain and the bsps with -mstrict-align in
multiple places. Configuring the MMU on these chips allows for unaligned
memory accesses for non-device memory which avoids requiring strict
alignment in the toolchain and in the BSPs themselves.
In writing this driver, it was found that the synchronous exception
handling code needed to be rewritten since it relied on clearing SCTLR_EL1 to
avoid thread stack misalignments in RTEMS_DEBUG mode. This is now
avoided by exactly preserving thread mode stack and flags and the new
implementation is compatible with the draft information provided on the
mailing list covering the Exception Management API.
Break out system register definitions and accessors so that they're
usable by other parts of RTEMS.
Ensure the stack remains aligned by keeping the context frame at a
multiple of 16 bytes. This avoids stack alignment exceptions which occur
when the stack pointer is not 16 byte aligned.
Commit 73ebf9a27ed5cd0fd3e0dc0da98345d7faa610a2 accidentally removed the
direct thread dispatch in a self thread restart. In case of a self
restart (always in task context) the directive shall not return. If
this is not possible due to a bad thread dispatch disable level, then a
fatal error shall occur.
Update #4412.
The _Thread_Cancel() (in contrast to _Thread_Restart() which used a
similar code block) may have produced ready threads with an active timer
in case the thread to cancel had its thread life protection enabled. The
problem was this code block:
Priority_Control priority;
_Thread_Add_life_change_request( the_thread );
if ( _Thread_Is_life_change_allowed( previous ) ) {
_Thread_State_release( the_thread, &lock_context );
_Thread_queue_Extract_with_proxy( the_thread );
_Thread_Timer_remove( the_thread );
} else {
_Thread_Clear_state_locked( the_thread, STATES_SUSPENDED );
priority = _Thread_Get_priority( executing );
_Thread_Raise_real_priority( the_thread, priority );
_Thread_Remove_life_change_request( the_thread );
The life change request should only be added/removed if a life change is
allowed (see _Thread_Restart()). Add _Thread_Try_life_change_request()
and use it in _Thread_Cancel() and _Thread_Restart().
Close #4435.
Move common code into _Thread_Exit(). This enables a tail call
optimization in most cases.
Add Thread_queue_Context::timeout_absolute to specify an absolute or
relative timeout. This avoid having to get the current time twice for
timeouts relative to the current time. It moves also functionality to
common code.
The __builtin_unreachable() cannot be used with current GCC versions to
tell the compiler that a function does not return to the caller, see:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99151
Add a no return variant of _CPU_Context_switch() to avoid generation of
dead code in _Thread_Start_multitasking() if RTEMS was built with SMP
support enabled.
Move this diagnostic function to a separate file since it does not
provide a core function of the system.
Change license to BSD-2-Clause according to file history and
re-licensing agreement.
Update #3053.
Add _Per_CPU_Is_ISR_in_progress() as an optimized version of
_ISR_Is_in_progress().
rtems_task_restart() may be called from within interrupt context. So
checking only that the thread to restart is equal to the executing
thread is insufficient to determine a self restart. We have to also
check that no ISR is in progress. Merge _Thread_Restart_other() and
_Thread_Restart_self() into one _Thread_Restart() since they share a lot
of common code.
Close #4412.
Unconditionally set the real priority of the task to its initial
priority during a task restart.
Close #4411.
This simplifies rtems_task_restart().
Use _Objects_Free_nothing() for rtems_message_queue_construct() to avoid
unreachable code in _CORE_message_queue_Close() in case only
user-provided message buffers are used.
Update #4007.
Rename _Stack_Free_nothing() in _Objects_Free_nothing() to make it
reusable for the message queue buffers.
Update #4007.
These two functions are no longer used outside of _Once().
Add a no return variant of _Thread_Dispatch_direct() to avoid generation
of dead code.
This may reduce the code size a bit.
CID 26033: Dereference after null check in _Objects_Extend_information().
Closes #4326
This avoids having conditional statements to get the API-specific status
code.
code.
In case the processor set is not large enough to contain the processor
affinity set of the task return RTEMS_INVALID_SIZE instead of
RTEMS_INVALID_NUMBER. This is more in line with other directives since
the issue is related to the size of an object.
Close #4393.
code.
Last use was removed by:
commit 54550e048d3a49435912797d2024f80671e93267
Author: Sebastian Huber <sebastian.huber@embedded-brains.de>
Date: Fri May 13 08:16:30 2016 +0200
posix: Rework pthread_join()
Rework pthread_join() to use _Thread_Join().
The _CPU_ISR_Is_enabled() function operates on ISR cookies and so must
mask off the appropriate status bits. This also fixes the naming of the
parameters of the _CPU_ISR_* functions to indicate use of ISR cookies
instead of interrupt enable/disable levels.
Replace Objects_Name_or_id_lookup_errors with new Status_Control codes.
Get rid of the _Status_Object_name_errors_to_status lookup table.
Do not adjust the stack area begin address since this may confuse the
stack allocator and result in failed stack frees.
Account for the alignment overhead in the stack space size estimate.
Check that the stack size is in the expected interval.
Move the CPU time budget to the thread configuration. This simplifies
_Thread_Initialize().
Overview
The errata is worked around in the kernel without requiring toolchain
modifications. It is triggered the JMPL/RETT return from trap instruction
sequence never generated by the compiler and. There are also other
conditions that must must be true to trigger the errata, for example the
instruction that the trap returns to has to be a JMPL instruction. The
errata can only be triggered if certain data is corrected by ECC
(inflicted by radiation), thus it can not be triggered under normal
operation. For more information see:
www.gaisler.com/notes
Affected RTEMS target BSPs:
* GR712RC
* UT699
* UT700/699E
The work around is enabled by defining __FIX_LEON3_TN0018 at build time.
After applying the following GCC patch, GCC will set the define when
compiling for an affected multilib:
* GR712RC (-mcpu=leon3 -mfix-gr712rc)
* UT700/UT699E (-mpcu=leon3 -mfix-ut700)
* UT699 (-mcpu=leon -mfix-ut699)
When building for another multilib and TN0018 is still required, it
is possible to enable it on the RTEMS kernel configure line using the
TARGET_CFLAGS (-D__FIX_LEON3FT_TN0018) or other by other means.
The following GCC patch sets __FIX_LEON3FT_TN0018 for the affected RTEMS
multilibs:
diff --git a/gcc/config/sparc/rtemself.h b/gcc/config/sparc/rtemself.h
index 6570590..ddec98c 100644
--- a/gcc/config/sparc/rtemself.h
+++ b/gcc/config/sparc/rtemself.h
@@ -33,6 +33,8 @@
builtin_assert ("system=rtems"); \
if (sparc_fix_b2bst) \
builtin_define ("__FIX_LEON3FT_B2BST"); \
+ if (sparc_fix_gr712rc || sparc_fix_ut700 || sparc_fix_ut699) \
+ builtin_define ("__FIX_LEON3FT_TN0018"); \
while (0)
Workaround Implementation
In general there are two approaches that the workaround uses:
A) avoid ECC restarting the RETT instruction
B) avoid returning from trap to a JMPL instruction
Where A) comes at a higher performance cost than B), so B) is used
where posssible. B) can be achived for certain returns from trap
handlers if trap entry is controlled by assembly, such as system calls.
A)
A special JMPL/RETT sequence where instruction cache is disabled
temporarily to avoid RETT containing ECC errors, and reading of RETT
source registers to "clean" them from incorrect ECC just before RETT
is executed.
B)
The work around prevents JMPL after system calls (TA instruction) and
modifies assembly code on return from traps jumping back to application
code. Note that for some traps the trapped instruction is always
re-executed and can therefore not trigger the errata, for example the
SAVE instruction causing window overflow or an float instruction causing
FPU disabled trap.
RTEMS SPARC traps workaround implementation:
NAME NOTE TRAP COMMENT
* window overflow 1 - 0x05 always returns to a SAVE
* window underflow 1 - 0x06 always returns to a RESTORE
* interrupt traps 2 - 0x10..1f special rett sequence workaround
* syscall 3 - 0x80 shutdown system - never returns
* ABI flush windows 2 - 0x83 special rett sequence workaround
* syscall_irqdis 4 - 0x89
* syscall_irqen 4 - 0x8A
* syscall_irqdis_fp 1 - 0x8B always jumps back to FP instruction
* syscall_lazy_fp_switch 5 - 0x04 A) jumps back to FP instruction, or to
B) _Internal_error() starting with SAVE
1) no workaround needed because trap always returns to non-JMPL instruction
2) workaround implemented by special rett sequence
3) no workaround needed because system call never returns
4) workaround implemented by inserting NOP in system call generation. Thus
fall into 1) when workaround is enabled and no trap handler fix needed.
5) trap handler branches into both 1) and returning to _Internal_error()
which starts with a SAVE and besides since it shuts down the system that
RETT should never be in cache (only executed once) so fix not necessary
in this case.
Any custom trap handlers may also have to be updated. To simplify that,
helper work around assembly code in macros are available in a separate
include file <libcpu/grlib-tn-0018.h>.
Close #4155.
Close #4336.
Update #4336.
Update #4336.
Run with stack alignment faults enabled under RTEMS_DEBUG to catch any
stack misalignments early. This makes it easier to track them down
should they ever occur.
The Per_CPU_Control::isr_dispatch_disable is a 32-bit integer.
Close #4206.
Make sure that a user-provided stack size is the minimum size allocated
for the stack.
Make sure we meet the stack alignment requirement also for CPU ports
with CPU_STACK_ALIGNMENT > CPU_HEAP_ALIGNMENT.
Clarify CPU_STACK_ALIGNMENT requirements in no_cpu port. Add static
assertion to enforce CPU_STACK_ALIGNMENT requirements.
Remove superfluous check for the objects maximum since the maximum is
also used as a loop limit.
Fix formatting.
Close the thread object if a thread create extension fails. Also call
the delete extension to avoid resource leaks in early extensions if a
late extension fails.
Close #4270.
Update #4267.
Update #4267.
Call _Thread_queue_Flush_critical() directly.
Use the number of threads which must arrive at the barrier to trip the
automatic release also to indicate if the barrier is a manual release
barrier.
Use the type safe _Objects_Open_u32() instead. Return the object
identifier to enforce a common usage pattern.
