* cpu.c: Remove warning.
* rtems/score/cpu.h: Revert change. It did not appear to correct all
warnings.
* rtems/score/cpu.h: Correct inline assembly constraints.
* cpu.c, rtems/score/sh.h: Recognize sh2e variant so multilibs will all
compile.
* .cvsignore: New file.
* rtems/score/cpu.h: Because gcc implicitly uses floating point turn on
floating point for all threads if there is a hardware FPU.
* rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/nios2.h,
rtems/score/types.h: New files.
* configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: New
port to Altera NIOS II.
* ChangeLog, Makefile.am, cpu.c, cpu_asm.S, irq.c, preinstall.am,
rtems/asm.h: New files.
Checked inline assembly; added early-clobber '&' to output operands
of multi-instruction asms.
* cpu_asm.S: Reduce mask from 0xffc to 0x3fc so only the vector
bits are used when calculating the exception vector.
* cpu.c: Added __mips==32 to fix build problems on those targets
caused by the Bruce Robinson.
B.Robinson patch
* cpu.c, cpu_asm.S: Fixed ARM Data Abort handling.
* cpu.c (_CPU_Initialize): Add fpu initialization.
* rtems/score/cpu.h: Setup CPU_*_ENDIAN from GCC's__MIPS{EL|EB}__.
(Partial merger of submission by Bruce Robinson <brucer@pmccorp.com>).
operations. The "memory" barrier will move the the generic interrupt
enable/disable/flash macros.
* rtems/score/cpu.h: Increase default stack size on i386 from 1K to 4K.
Most i386 targets are not memory strapped so making this a bit large
is not a burden. It lets more tests run. ticker and psxtimer will not
even run with 1K of stack.
Large patch to improve Doxygen output. As a side-effect, grammar and
spelling errors were corrected, spacing errors were address, and some
variable names were improved.
* libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h:
Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS.
* score/Doxyfile: Set output directory. Predefine some macro values.
Turn on graphical output.
* score/include/rtems/debug.h, score/include/rtems/seterr.h,
score/include/rtems/system.h, score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/apimutex.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/context.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/heap.h, score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h,
score/include/rtems/score/tqdata.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/tqdata.inl, score/macros/README,
score/src/heap.c, score/src/threadmp.c, score/src/threadready.c,
score/src/threadstartmultitasking.c: Improve generated Doxygen
output. Fix spelling and grammar errors in comments. Correct names of
some variables and propagate changes.
* rtems/score/cpu.h: Part of a large patch to improve Doxygen output.
As a side-effect, grammar and spelling errors were corrected, spacing
errors were address, and some variable names were improved.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h,
* rtems/asm.h, rtems/score/cpu.h, rtems/score/types.h: Part of a large
* rtems/score/types.h: Eliminate unsigned16.
* rtems/score/cpu.h: Eliminate use of unsigned32.
* rtems/score/types.h: Eliminate unsigned16, unsigned32.
* rtems/powerpc/registers.h: recognize mpc7457 CPU; added definitions
for high bats (#4..7) on 7450 CPUs
* rtems/asm.h: Remove private version of CONCAT macros.
Include <rtems/concat.h> instead.
PR 365/rtems
* rtems/score/arm.h, rtems/score/cpu.h: Removed unused ARM_HAS_CLZ
macro
PR 803/patch
* rtems/score/cpu.h, rtems/score/m68k.h: Correct definition of _VBR.
* rtems/score/cpu.h, rtems/score/m68k.h: Change declaration of _VBR.
* rtems/score/powerpc.h: Removed warning
* rtems/score/m68k.h: Change _ColdFire_VBR to _VBR.
* rtems/score/cpu.h: Change definition of _VBR to a simple pointer.
* rtems/score/m68k.h: Remove use of _Coldfire_VBR.
* rtems/asm.h: Eliminate warnings.
* score/cpu/Makefile.am: Remove or32 (target abandoned).
