for details.
PR 1932/cpukit
* cpu_asm.S: At some point the interrupt trap handler causes a
window-overflow and the window overflow trap handler crashes when
writing to 0. I found that this is because the WIM was bad, to the
window overflow handler uses a uninitialized stack pointer in a
window never used.
* g3=CWP, not WIM
* CWP is incremented by done_flushing no need doing that here also
* I see no reason to create an additional stack frame (save)
* Must turn off traps when updating WIM (maybe already done by caller?)
PR 1914/cpukit
* rtems/score/cpu.h: Select timestamp implementation.
* cpu.c: Remove /*PAGE markers which were interpreted by a long dead
print script.
* rtems/score/cpu.h, rtems/score/sparc.h, rtems/score/types.h: Convert
comments to Doxygen style and improve.
* Makefile.am: Reformat.
* rtems/score/sparc.h: Remove warnings.
PR 1729/cpukit
* configure.ac, sapi/include/confdefs.h, sapi/src/exinit.c,
score/Makefile.am, score/preinstall.am,
score/cpu/i386/rtems/score/cpu.h, score/cpu/sparc/cpu_asm.S,
score/cpu/sparc/rtems/score/cpu.h,
score/include/rtems/score/basedefs.h,
score/include/rtems/score/context.h,
score/include/rtems/score/percpu.h, score/src/percpu.c,
score/src/thread.c, score/src/threadcreateidle.c: Add next step in
SMP support. This adds an allocated array of the Per_CPU structures
to support multiple cpus vs a single instance of the structure which
is still used if SMP support is disabled. Configuration support is
also added to explicitly enable or disable SMP. But SMP can only be
enabled for the CPUs which will support it initially -- SPARC and
i386. With the stub BSP support, a BSP can be run as a single core
SMP system from an RTEMS data structure standpoint.
* aclocal/check-smp.m4, aclocal/enable-smp.m4,
score/include/rtems/bspsmp.h, score/include/rtems/score/smplock.h,
score/src/smp.c, score/src/smplock.c: New files.
* rtems/score/cpu.h, rtems/score/sparc.h:
* cpu.c: Remove unused variable reported by clang.
* rtems/score/cpu.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE to
_CPU_Context_restore() because it does not return. Telling GCC this
avoids generation of dead code.
PR 1635/cpukit
* rtems/score/types.h: Refactoring of priority handling, to isolate the
bitmap implementation of priorities in the supercore so that priority
management is a little more modular. This change is in anticipation
of scheduler implementations that can select how they manage tracking
priority levels / finding the highest priority ready task. Note that
most of the changes here are simple renaming, to clarify the use of
the bitmap-based priority management.
* rtems/score/cpu.h: Include <rtems/score/types.h> first.
* rtems/score/types.h: Use <rtems/score/basedefs.h> header file.
PR 1573/cpukit
* cpu_asm.S, rtems/score/cpu.h: Add a per cpu data structure which
contains the information required by RTEMS for each CPU core. This
encapsulates information such as thread executing, heir, idle and
dispatch needed.
* cpu.c, cpu_asm.S: Add include of config.h
PR 1385/cpukit
* cpu_asm.S: When the type rtems_boolean was switched to the C99 bool,
the size changed from 4 bytes to 1 byte. The interrupt dispatching
code accesses two boolean variables for scheduling purposes and the
assembly implementations of this code did not get updated.
* rtems/score/cpu.h: Change prototype of IDLE thread to consistently
return void * and take a uintptr_t argument.
* cpu.c, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and
passing address of _Thread_Dispatch to _CPU_Initialize. Clean up
comments.
* rtems/score/types.h: Do not define boolean, single_precision,
double_precision unless RTEMS_DEPRECATED_TYPES is given.
* cpu.c: Remove extraneous spaces.
* cpu.c, rtems/score/cpu.h: Convert to "bool".
* rtems/score/types.h: Include stdbool.h.
Use bool as base-type for boolean.
PR 1294/bsps
* rtems/score/cpu.h, rtems/score/sparc.h: Correct prototype and usage
of sparc_disable_interrupts.
* rtems/score/cpu.h: Spacing.
* rtems/score/cpu.h: Correct prototype of Idle threads.
* rtems/score/cpu.h: Add CPU_SIMPLE_VECTORED_INTERRUPTS porting
parameter to indicate that the port uses the Simple Vectored
Interrupt model or the Programmable Interrupt Controller Model. The
PIC model is implemented primarily in the BSP and it is responsible
for all memory allocation.
PR 1278/cpukit
* cpu.c: Fix incorrect bit manipulation on returning old address of raw
trap handler.
* rtems/score/cpu.h: Add _CPU_Context_Get_SP() for stack check utility.
* cpu.c, rtems/score/cpu.h: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
* rtems/score/cpu.h: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* score/cpu/sparc/cpu.c, score/cpu/sparc/rtems/score/cpu.h,
score/include/rtems/score/context.h, score/src/threadhandler.c: Fix
stack so gdb backtrace does not print corrupted frame message after
_Thread_Handler. Daniel Hellstrom <daniel@gaisler.com> provided the
SPARC implementation and I made it more general.
* score/cpu/arm/cpu.c, score/cpu/avr/cpu.c, score/cpu/bfin/cpu.c,
score/cpu/c4x/cpu.c, score/cpu/h8300/cpu.c, score/cpu/i386/cpu.c,
score/cpu/m68k/cpu.c, score/cpu/mips/cpu.c, score/cpu/nios2/cpu.c,
score/cpu/no_cpu/cpu.c, score/cpu/sh/cpu.c, score/cpu/sparc/cpu.c,
cpukit/sapi/src/exinit.c: Move copying of CPU Table to shared
executive initialization.
PR 1237/rtems
* cpu.c, cpu_asm.S, rtems/score/cpu.h: Add logic to prevent stack creep
when interrupts occur at a sufficient rate that the interrupted
thread never gets to clean its stack. This patch ensures that an
interrupted thread will not nest ISR dispatches on its stack.
* rtems/score/cpu.h: Remove CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
* cpu.c:
Use Context_Control_fp* instead of void* for fp_contexts.
Eliminate evil casts.
* rtems/score/types.h: Remove unsigned64, signed64.
* cpu_asm.S: Properly support synchronous traps.
* rtems/score/cpu.h: Part of a large patch to improve Doxygen output.
As a side-effect, grammar and spelling errors were corrected, spacing
errors were address, and some variable names were improved.
