In particular CPU_INTERRUPT_NUMBER_OF_VECTORS and
CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER are only used on
Simple Vectored Architectures, so do not depend on
them being defined. This disables as much as possible
that is specific to the Simple Vectored Model and
not expected to be used on architectures which use
the Programmable Interrupt Controller model for
interrupt handler vectoring.
This commit covers at least PR2020, 2022, and 2023. This
patch adds all of the code for both BSPs, modifications
to libcpu/powerpc for the ppc440, and some updates to the
BSPs from follow up review and testing.
These BSPs should be good baselines for future development.
The configurations used by Ric are custom and have a non-standard
NIC. They also do not have a UART. Thus the current console
driver just prints to a RAM buffer.
The NIC and UART support are left for future work. When the UART
support is added, moving the existing "to RAM" console driver to
a shared location is likely desirable because boards with no debug
UART port are commonly deployed. This would let printk() go to RAM.
* rtems/powerpc/registers.h: More register defines.
PR 1914/cpukit
* rtems/score/cpu.h: Select timestamp implementation.
* rtems/score/cpu.h: Add more context access functionality. Needed to
get GDB debugger hooks working.
* rtems/powerpc/registers.h: Renamed defines XER in PPC_XER, LR in
PPC_LR, CTR in PPC_CTR, PVR in PPC_PVR, RPA in PPC_RPA, DAR in
PPC_DAR, DEC in PPC_DEC, and EAR in PPC_EAR.
* rtems/score/cpu.h: Added SPE support to CPU context.
* rtems/powerpc/registers.h: Added FSL_EIS_SVR define.
* rtems/powerpc/registers.h: Added FSL_EIS_ATBL, FSL_EIS_ATBL, and
FSL_EIS_SPEFSCR defines.
* rtems/powerpc/registers.h: Added MSR_UCLE, MSR_SPE, MSR_WE, and
MSR_UBLE defines.
* rtems/powerpc/registers.h, rtems/score/cpu.h:
* rtems/powerpc/registers.h: Changed Freescale EIS prefix. More
Freescale EIS defines. Added MSR_IS, MSR_DS, and MSR_PMM defines.
* include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/irq.h,
score/cpu/i386/rtems/score/idtr.h,
score/cpu/powerpc/rtems/powerpc/registers.h,
score/src/objectidtoname.c, score/src/schedulerpriorityblock.c,
score/src/schedulerpriorityschedule.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriorityyield.c, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threadclose.c, score/src/threadcreateidle.c,
score/src/threaddelayended.c, score/src/threaddispatch.c,
score/src/threadget.c, score/src/threadhandler.c,
score/src/threadready.c, score/src/threadreset.c,
score/src/threadrestart.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadstackallocate.c,
score/src/threadstackfree.c, score/src/threadstart.c,
score/src/threadstartmultitasking.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c, score/src/threadyieldprocessor.c:
Fix typo where license said found in found in.
* rtems/powerpc/registers.h: Added BOOKE_PIR define.
* rtems/powerpc/registers.h: Added HID2 define. Fixed comments.
* rtems/score/cpu.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE to
_CPU_Context_restore() because it does not return. Telling GCC this
avoids generation of dead code.
PR 1635/cpukit
* rtems/score/cpu.h, rtems/score/types.h: Refactoring of priority
handling, to isolate the bitmap implementation of priorities in the
supercore so that priority management is a little more modular. This
change is in anticipation of scheduler implementations that can
select how they manage tracking priority levels / finding the highest
priority ready task. Note that most of the changes here are simple
renaming, to clarify the use of the bitmap-based priority management.
* rtems/new-exceptions/cpu.h: Removed file.
* Makefile.am, preinstall.am: Reflect change above.
* rtems/score/cpu.h: Include <rtems/score/types.h> first. Added
contents of <rtems/new-exceptions/cpu.h>.
* rtems/score/types.h: Use <rtems/score/basedefs.h> header file.
PR 1588/cpukit
* rtems/powerpc/registers.h: Renamed defines SR0 .. SR15 in
PPC_SR0 .. PPC_SR15.
PR 1573/cpukit
* rtems/new-exceptions/cpu.h: Add a per cpu data structure which
contains the information required by RTEMS for each CPU core. This
encapsulates information such as thread executing, heir, idle and
dispatch needed.
* score/cpu/powerpc/rtems/score/cpu.h: Added space for non-
volatile AltiVec registers to context struct. Added declaration
for AltiVec-related routines to be implemented by CPU/BSP
support.
* rtems/score/cpu.h: Changed fpscr field to an integer type in
Context_Control_fp. Fixed warnings in PPC_Set_timebase_register().
Changed _CPU_Context_Initialize_fp() to initialize all fields and
avoid floating-point instructions.
* rtems/score/powerpc.h: Removed PPC_INIT_FPSCR define.
Standards (EIS) special purpose register definitions for MMU and L1
cache.
* rtems/new-exceptions/cpu.h, rtems/score/cpu.h: Eliminate
_CPU_Thread_dispatch_pointer and passing address of _Thread_Dispatch
to _CPU_Initialize. Clean up comments.
* rtems/score/cpu.h: Move extern of bsp_clicks_per_usec so it is not
nested inside braces.
* rtems/score/types.h: Do not define boolean, single_precision,
double_precision unless RTEMS_DEPRECATED_TYPES is given.
* rtems/powerpc/registers.h: Removed obsolete defines MSR_, MSR_KERNEL
and MSR_USER. Added missing prototypes.
* rtems/new-exceptions/cpu.h: Changed define
CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER to UINT32_MAX to avoid comparison
between signed and unsigned.
fixed some minors in mpc83xx support
added file for mpc55xx watchdog support
* score/cpu/powerpc/rtems/new-exceptions/cpu.h:
use ppc_interrupt_get_disable_mask() to determine
which bits to set/clear from _CPU_ISR_Set_level().
* score/cpu/powerpc/rtems/powerpc/registers.h:
added ppc_interrupt_get_disable_mask() inline function.
* cpukit/score/cpu/powerpc/rtems/new-exceptions/cpu.h,
cpukit/score/cpu/powerpc/rtems/score/cpu.h,
cpukit/score/cpu/powerpc/rtems/score/powerpc.h:
Removed all macro definitions which depended on
the compiler defining a PPC CPU-model dependent
symbol.
Macros which were not used by cpukit have been
moved to libcpu/powerpc/rtems/powerpc/powerpc.h.
* posix/src/keycreate.c, posix/src/pthreadequal.c,
rtems/src/semtranslatereturncode.c,
score/cpu/powerpc/rtems/score/powerpc.h,
score/src/threadblockingoperationcancel.c: Fix compilation errors
when --enable-rtems-debug is used.
* rtems/score/cpu.h: Add _CPU_Context_Get_SP() for stack check utility.
* rtems/powerpc/registers.h, rtems/score/cpu.h: Sweep to make sure grep
for COPYRIGHT passes.
* rtems/powerpc/registers.h: added definitions for MSR_CE,
MSR_DE (bookE).
* rtems/old-exceptions/cpu.h: Remove extra ifndef.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h,
rtems/score/cpu.h: Move interrupt_stack_size field from CPU Table to
Configuration Table. Eliminate CPU Table from all ports. Delete
references to CPU Table in all forms.
* rtems/score/cpu.h: Added comment that GDB patch sim/2376
is needed for reading the time-base with the new (more
portable) method.
